sam_glanza_v Posted January 31, 2017 Posted January 31, 2017 Hi lads. Just wondering if anyone can shed some light on what possible oil i need for my 1997 EP91 Glanza V. I'm pretty sure I have an LSD. But just to be double sure is there a way of checking without taking the gearbox off? I know on the sticker on the inside of the car it does state I have an LSD. Im just aware that I need LSD specific oil. If anyone could recommend a good oil that would be great. Thanks for the continued help lads. Sam Miller. Quote
Ryncewind Posted January 31, 2017 Posted January 31, 2017 Jack the front of the car up so both wheels are off the ground, Spin one wheel, If the other wheel spins in the same direction you have an LSD, If it spins in the opposite direction you have an open differential. Quote
starletezy Posted January 31, 2017 Posted January 31, 2017 I'm using 75w90 on my OEM LSD gear box will do the job fine Quote
sam_glanza_v Posted February 1, 2017 Author Posted February 1, 2017 Jack the front of the car up so both wheels are off the ground, Spin one wheel, If the other wheel spins in the same direction you have an LSD, If it spins in the opposite direction you have an open differential.Thanks very much mate I shall do this once we get some good weather 😂I'm using 75w90 on my OEM LSD gear box will do the job fineThanks mate appreciate that it's good to know Quote
dan106 Posted February 1, 2017 Posted February 1, 2017 i have read the oem lsd doesn't need lsd specific oil, is it true? Quote
starletezy Posted February 1, 2017 Posted February 1, 2017 i have read the oem lsd doesn't need lsd specific oil, is it true?Doesn't no mate Quote
morgey Posted February 1, 2017 Posted February 1, 2017 Oem lsd will be helical/torsen type most likely these require very little servicing basically standard gearbox oil changes.Its only really clutch type lsds (mainly aftermarket) that require special lsd oils and regular service internals Quote
dan106 Posted February 2, 2017 Posted February 2, 2017 Ah that's a result then, already got box oil for my new gearbox then lol Quote
TrisK Posted February 2, 2017 Posted February 2, 2017 Ah that's a result then, already got box oil for my new gearbox then lolDan you cant reuse the oil from your old gearbox, thats not a valid money saving method Quote
dan106 Posted February 2, 2017 Posted February 2, 2017 Dan you cant reuse the oil from your old gearbox, thats not a valid money saving method Quote
