Nilz90 Posted May 29, 2017 Posted May 29, 2017 Hi, I'm trying to buy a caliper slider pin kit for my car. Does anyone know which calipers these are? I was told they are from a Celica but not sure as there are two different ones for the GT4. Thanks Quote
morgey Posted May 30, 2017 Posted May 30, 2017 If theyre celica twinpots they will be st165. But you also get ae111 levin twinpots or mr2 sw20 twinpots. You can try and run the part numbers through toyodiy.com and see if they use the same sliders to narror down if theyre different or not Quote
morgey Posted May 30, 2017 Posted May 30, 2017 Can you confirm if they are single or twinpot calipers?looking at pics online they dont look like either st165 or 185 celica gt4 calipers and st205 are completely different.They could be celica st202 ones or if twinpots mr2 and ae111s use the same slider pins Quote
Nilz90 Posted May 31, 2017 Author Posted May 31, 2017 Hi mate I just took the wheel off it is a single pot one? Quote
morgey Posted May 31, 2017 Posted May 31, 2017 At best guess its an st185 its hard to tell if yours has a single rubber boot at either end or 2 at either end. If its got 2 either end then its st185. http://www.gtfours.co.uk/pics/brakes/all_brakes2.jpg Quote
Nilz90 Posted June 1, 2017 Author Posted June 1, 2017 I think it looks like St185 too.This is the back of the caliper.http://i892.photobucket.com/albums/ac122/n1lz/IMG_4086.jpg Quote
Flynn Posted June 1, 2017 Posted June 1, 2017 Mine are st 185's got one off to rebuild it, hang fire I'll take a picture! Quote
T-dog Posted June 1, 2017 Posted June 1, 2017 I would say they are not st185 calipers , they look like the standard celica 1.8 ones Quote
turbominicooper Posted June 2, 2017 Posted June 2, 2017 St185 had both twin and 4 pothttps://youtu.be/3brj6Eb0vAY Quote
gorganl2000 Posted June 2, 2017 Posted June 2, 2017 (edited) from what i can tell http://s892.photobucket.com/user/n1lz/media/IMG_4078.png.html this look very much like this http://www.ebay.com/itm/92-96-Toyota-Camry-OEM-front-brake-calipers-with-brackets-V6/201600115593 got to the 3rd pic and zoom in to compare Edited June 2, 2017 by gorganl2000 Quote
morgey Posted June 2, 2017 Posted June 2, 2017 St185 had both twin and 4 pothttps://youtu.be/3brj6Eb0vAYIf you look on google images the st185 had single pot caliper too lol Quote
Nilz90 Posted June 5, 2017 Author Posted June 5, 2017 Cheers guys for your help. I'll try and figure out which ones they could be. Quote
SKINY Posted June 6, 2017 Posted June 6, 2017 (edited) Early 185s had twin pot and later had single. 255mm/277mm discs too. The st205 came with the 4 pots I will be using the early twin pots and astra discs soon enough Edited June 6, 2017 by SKINY Quote
