turbominicooper Posted June 17, 2017 Posted June 17, 2017 Just recently finished a 2e to 4efte conversion.When the car runs it smells very rich and is quite smokey.On the 2e it had a 2 wire lambda and ov the 4efte one is single wire.Is it likely to be faulty lambda?Pretty sure I traced the correct wire to the ecu for the sensor. Quote
maerijn Posted June 17, 2017 Posted June 17, 2017 All 4 plugs black? Could be bad lambda, water sensor or othet things. Is the ecu giving any codes Quote
Ollieh17 Posted June 18, 2017 Posted June 18, 2017 I doubt it's lambda. I ran mine without for ages and made no difference on the wideband Quote
turbominicooper Posted June 18, 2017 Author Posted June 18, 2017 I'll revisit the wiring. Cheers fellas Quote
Patches Posted June 21, 2017 Posted June 21, 2017 Running no lambda and a faulty one are 2 different things. If there's no lambda plugged in then the ecu knows that and runs a slightly richer map for safety. If the lambda is faulty giving wrong readings then the ecu will try to fuel according to that reading. My lambda sensor was reading rich constantly so my ecu was underfuelling the car causing it to run like shit. Unplugged the sensor and it ran fine. Quote
Ollieh17 Posted June 21, 2017 Posted June 21, 2017 Car didn't run differently on the wideband with no lambda and a working lambda..Could just be my car but never noticed a difference. With or without idled at 14.5-15 Quote
federalman Posted October 23, 2017 Posted October 23, 2017 On 6/21/2017, 12:12:57, Ollieh17 said: Car didn't run differently on the wideband with no lambda and a working lambda.. Could just be my car but never noticed a difference. With or without idled at 14.5-15 Mine runs fine without a lambda and its not been in there since I fitted the TD04, numbers are a bit sloppy on idle but on boost it runs fine but rather rich. PLugs look absolutely fine and I'd rather run rich than lean personally. From what I read the lambda is only really noted on idle, after that the map sensor takes over. Quote
