6 speed on a n/a has it been done? Is it worth doing? Do you need a different clutch? Is there a code on the side of the box to tell if it’s a six speed n not a five? Help would be appreciated.
Thanks Dan
Thanks Dan
toyota did poorly with labeling the gearboxes. but the 6 speed is easy to spot when you look at the end cap that covers 5th and 6th gears, its shaped different to the 5 speeds there and longer.
I think the corolla 6 speed box is a C152 box? They are a direct bolt on, don't need to swap the clutch etc. Only think that needs modifying is the shifter in the car. I had to file down the inside of the plastic housing to allow the shifter room to select reverse (next to first on these boxes)
16 hours ago, morgey said:
Corolla g6 with the 4efe 1.3 is a direct bolt on. The 4afe box can be used but need to swap bell housings.
I have the G6 4efe box on my GT, have done for years, best thing I ever did!
kinda jelous, the g6 box doesnt exist in my market, and 6 speeds in general are like diamonds here. one of those would polish my build off nicely.
C161  final drive 4.529
1st       2nd      3rd     4th     5th     6th
3.166 1.904 1.233  0.969  0.815  0.628
C56 final drive 4.312
1st       2nd      3rd       4th      5th
3.166  1.904  1.392  1.031  0.815
Both use the same reverse by the looks of it 3.250
C161 is what we in the UK are most likely to find out the corolla g6
The levin ae111 uses the C160  I believe has a shorter 2nd-5th gears
And I've just compared it against the most common glanza Gbox (C56)
Hope this helps
are you sure about that final drive for the glanza ep91 c56?
as far as i have investigated, the ep91 glanza has a 3.722 final drive c56
however, the levin c56 seems to have the 4.312 final drive you noted above
may be someone can clarify
