Glanza_v9797 Posted January 27, 2018 Posted January 27, 2018 As the title says my ep91 wheel bearing keeps on going every 6 weeks but not sure why its doing so. anyone had experiences like this or similar ? Quote
akyakapotter Posted January 27, 2018 Posted January 27, 2018 Rears? If so check the axel isn't worn. Cheers nick Quote
patman Posted January 27, 2018 Posted January 27, 2018 I ordered some once mate and they lasted not even a year think that was from japserviceparts, who’s doing them for you, are they being pressed in properly and greased right, also when doing up the driveshaft nut is that at the right torque? Quote
Glanza_v9797 Posted January 27, 2018 Author Posted January 27, 2018 Same person doing it had them changed about twice in the last 6 months all on the same side front rh side? im guessing it is the talk settings if anything? Quote
Calum122 Posted January 28, 2018 Posted January 28, 2018 When I did my front wheel bearings, I noticed the hub was completely mangled. The chap who was going to press it in claimed he didn't damage whilst angle grinding off the old one. But told me we could fit a new bearing in. At which point I had to stop and say to him, it's failed for a reason, this looks like the reason. So, if the hub is damaged, and you aren't aware, then that could be why. I only needed the press, but the rest of the work I do myself, so I was able to make that decision. Quote
maerijn Posted January 30, 2018 Posted January 30, 2018 (edited) On 27-1-2018 22:58:51, akyakapotter said: Rears? If so check the axel isn't worn. Cheers nick If so how to repair the rear axle? I think I have this problem Edited January 30, 2018 by maerijn Quote
akyakapotter Posted January 30, 2018 Posted January 30, 2018 Every one I've seen people replace the axel. Cheers nick Quote
5e colin Posted January 30, 2018 Posted January 30, 2018 What brand bearing are you buying and where from is he using.g a greas packer or just fitting the bearing strait out of the box !!!! See I all the time by wannabe mechanics in many garages Quote
Glanza_v9797 Posted February 3, 2018 Author Posted February 3, 2018 just got new bearing in from idworkz see how she goes for now Quote
5e colin Posted February 3, 2018 Posted February 3, 2018 just make sure you pack them fukll of grease with a grease packer just rubbing them in by hand is not really sufficiant Quote
