wakeabby14 Posted March 16, 2018 Posted March 16, 2018 Does the block need to be drilled to support them or do they fit in the existing head bolt holes. Cheers Quote
daniel_g Posted March 16, 2018 Posted March 16, 2018 The head bolts are straight fit. Its the head studs that require machine work. Quote
wakeabby14 Posted March 16, 2018 Author Posted March 16, 2018 24 minutes ago, daniel_g said: The head bolts are straight fit. Its the head studs that require machine work. Is it better to go for studs or bolts? Is it correct when you use studs, you need to do machine work near the cams in the head so you can fit a socket bit in to tighten them up? Quote
maddox710 Posted March 16, 2018 Posted March 16, 2018 Waste of time and money with studs(unless using large garret running big big boost numbers) just get bolts Quote
wakeabby14 Posted March 16, 2018 Author Posted March 16, 2018 38 minutes ago, maddox710 said: Waste of time and money with studs(unless using large garret running big big boost numbers) just get bolts sound nice one mate! Will do Quote
daniel_g Posted March 16, 2018 Posted March 16, 2018 Studs are better but you have to strip the block down, ie rods and pistons out the machine the block. The head needs work aswell. ARP bolts will be good enough for most builds. Quote
wakeabby14 Posted March 16, 2018 Author Posted March 16, 2018 4 minutes ago, daniel_g said: Studs are better but you have to strip the block down, ie rods and pistons out the machine the block. The head needs work aswell. ARP bolts will be good enough for most builds. thanks mate appreciate it Quote
maddox710 Posted March 16, 2018 Posted March 16, 2018 57 minutes ago, daniel_g said: Studs are better but you have to strip the block down, ie rods and pistons out the machine the block. The head needs work aswell. ARP bolts will be good enough for most builds. As Dan said a lot of work goes into putting studs in when most people just wanna max a td04 out Quote
gorganl2000 Posted March 17, 2018 Posted March 17, 2018 (edited) 20 hours ago, maddox710 said: As Dan said a lot of work goes into putting studs in when most people just wanna max a td04 out so true.... Edited March 17, 2018 by gorganl2000 Quote
