starlybruiser Posted April 15, 2008 Posted April 15, 2008 I have a glanza v and the tops of the lens on both head lights are sorta ruff?? they look as if they have been rubbed a bit with fine sand paper. any ideas if theres anything on the market to get these looking like new again?? any help is much appreciated, cheers guys starlybruiser ;) Quote
nic1.3 Posted April 15, 2008 Posted April 15, 2008 i may well never lok like new again but maybe try sum very fine wet and dry sand paper and give it a savage sanding with this and then use sum light abrasive polish like autoglym paint renovator..... it mite help..... Quote
Bourkey Posted April 15, 2008 Posted April 15, 2008 Sounds like they had headlight brows on them to me. but do what ^^^ said and they should be ok aftter a lot of scrubbing.Bourkey Quote
starlybruiser Posted April 16, 2008 Author Posted April 16, 2008 Sounds like they had headlight brows on them to me. but do what ^^^ said and they should be ok aftter a lot of scrubbing.BourkeyOr it could an Excuse to put brows on her ;) haha i think i will try the rubbing, if no joy then i will go for the brows. cheers for the advise guys starlybruiser ;) Quote
dobbs Posted April 29, 2008 Posted April 29, 2008 hi there. i would recomend maguires plastix.its great on light scuffs and discoloring on lenses. rub down the affected area with some 1000 grit paper, if its not working, start with a 320 grit, then work your way up 320 - 500 - 800 - 1000 overlapping the area each time. then the plastix should polish it up a treat.it will take alot of elbow grease to polish it up, but it will be worth it. alternativly you could use a machine polisher... IF your carefull.HTH ;) Quote
Tahiti Posted May 2, 2008 Posted May 2, 2008 as above!Brother's used it on his Elise headlight covers and they were greatly improved. Quote
StarletRick Posted May 2, 2008 Posted May 2, 2008 just polish the shit out of them with cutting compound. youll sweat like a whore, but theyll come up nice and you wont need to sand them down. Quote
starlybruiser Posted May 2, 2008 Author Posted May 2, 2008 well i tried 3g cutting compound and it has helped a bit but i didnt have much time to stick at it, but hopefully it will clean up, if not then i will try that plastix stuff, thanks for the help guys Quote
StarletRick Posted May 2, 2008 Posted May 2, 2008 the 3g will work youll just have to put a good 15 mins into the light to get it done nice. once youve done it once youll be ok with a 2 minute buff up when you wash it. Quote
