SpenceGT Posted September 12, 2018 Posted September 12, 2018 how can u tell if u have a lsd or not 20180912_132433.mp4 Quote
SKINY Posted September 12, 2018 Posted September 12, 2018 Different rear gearbag mount I know bud, think case is different too, will send ya pics of my non lsd mount later my favourite method would be launching it getting it spinning and see if you've left an 11 or a 1 lol Quote
Calum122 Posted September 12, 2018 Posted September 12, 2018 When the car is jacked up and in neutral, if an LSD is fitted, you can rotate one of the wheels and the other will spin. Obviously if it's in gear then both wheels will spin since all cars will have a differential, but in neutral it should not spin. Quote
maddox710 Posted September 12, 2018 Posted September 12, 2018 (edited) The rear gearbox mount is 2 piece, the main bulk of it is alloy and it has a flat black steel cross peice Also both Driveshafts are more or less the same size Edited September 12, 2018 by maddox710 Added to it Quote
garbs Posted September 13, 2018 Posted September 13, 2018 Is it only the factory optional lsd that uses the different gearbox mount? so a quaife/cusco/kaaz lsd etc could be fitted into a standard box with a standard mount? Quote
Calum122 Posted September 13, 2018 Posted September 13, 2018 4 hours ago, garbs said: Is it only the factory optional lsd that uses the different gearbox mount? so a quaife/cusco/kaaz lsd etc could be fitted into a standard box with a standard mount? Yes, you can fit an LSD to a Non-LSD box. 18 hours ago, maddox710 said: The rear gearbox mount is 2 piece, the main bulk of it is alloy and it has a flat black steel cross peice Also both Driveshafts are more or less the same size That's really interesting. So that could potentially eliminate some torque steer if the driveshafts are similar in size. Quote
Ollieh17 Posted September 13, 2018 Posted September 13, 2018 19 hours ago, Calum122 said: When the car is jacked up and in neutral, if an LSD is fitted, you can rotate one of the wheels and the other will spin. Obviously if it's in gear then both wheels will spin since all cars will have a differential, but in neutral it should not spin. This doesnt always work as some need load on them Quote
HedgeyGedgey Posted October 1, 2018 Posted October 1, 2018 On 9/13/2018 at 2:44 PM, Ollieh17 said: This doesnt always work as some need load on them I know with my OEM LSD, it needs load to lock up. So wheels turned, dump clutch coming out of junction it'll leave a 1 wheel peel. But load up the car first, get it crawling and then do the same it'll spin both wheels Quote
