Sign in to follow this
dcbr
Top speed on forged td04?
hi I had my forged glanza mapped yesterday
Made 271hp 320tq
I went out on a "private road" to see what I can get out of it. In 5th gear at around 120mph it feels like I've hit a brick wall the car just cuts. As far as I know the e manage ultimate removes the speed limiter on the car. Its also converted to mph
Standard glanza box non Ltd
195/50/15 tyres and 6520rpm rev limit
If anyone can lead me in the direction of the problem it would be much appreciated.
Thanks in advance
Share this post
Interesting.
From what I've read speed cut is 110mph, and the speed cut defenders are the best option, these also convert kph to mph.
How have you converted kph to mph.
Share this post
The rpm limit on a 4EFTE is 7200rpm.
Thats probably the issue.
Your missing 700rpm, so that would add to the top speed
Edited by 5T4R7ET N/A
Share this post
On my 4e I had speed cut come in around 118mph. You got a couple options. You'll have to search the forum for details but you can cut the yellow wire (if I'm not mistaken should be gas) and deal with a check engine light (can install switch when u want to go over the certain speed and switch off when not using to work around check engine light) or get a speed limiter defender
Share this post
