dcbr Posted July 16, 2020 Posted July 16, 2020 hi I had my forged glanza mapped yesterday Made 271hp 320tq I went out on a "private road" to see what I can get out of it. In 5th gear at around 120mph it feels like I've hit a brick wall the car just cuts. As far as I know the e manage ultimate removes the speed limiter on the car. Its also converted to mph Standard glanza box non Ltd 195/50/15 tyres and 6520rpm rev limit If anyone can lead me in the direction of the problem it would be much appreciated. Thanks in advance Quote
Sam44 Posted July 16, 2020 Posted July 16, 2020 Interesting. From what I've read speed cut is 110mph, and the speed cut defenders are the best option, these also convert kph to mph. How have you converted kph to mph. Quote
akyakapotter Posted July 16, 2020 Posted July 16, 2020 I have done 156mph on a private road / track in my v. Something seams up with yours the mph convert on the box should derestrict it anyway. Quote
5T4R7ET N/A Posted July 17, 2020 Posted July 17, 2020 (edited) The rpm limit on a 4EFTE is 7200rpm. Thats probably the issue. Your missing 700rpm, so that would add to the top speed Edited July 17, 2020 by 5T4R7ET N/A Quote
mycars12 Posted July 18, 2020 Posted July 18, 2020 On my 4e I had speed cut come in around 118mph. You got a couple options. You'll have to search the forum for details but you can cut the yellow wire (if I'm not mistaken should be gas) and deal with a check engine light (can install switch when u want to go over the certain speed and switch off when not using to work around check engine light) or get a speed limiter defender Quote
