Sign in to follow this
Goldie
Forged Engine Maintenance
Hi all, possibly a daft question however I wondered if and what additional maintenance/upkeep should be made on a forged engine to keep her sweet. Thank you
Share this post
There are no daft questions mate!
Wouldn't say there was any special maintenance because an engine is forged, it's more the power level and how it's driven that will reduce service intervals.
Most track cars get an oil and filter change after each track day due to the nature of the driving.
If it's sensible power output and mixed street driving then the normal change intervals should be fine. If you wanted to be safer then reduce the oil service interval to 2k miles.
Always use quality fully synthetic oil of the correct grade and a quality oil filter.
Avoid separate oil additives and oil flushes, imho they aren't necessary as modern oils are excellent and have all the detergents and additives required already.
Share this post
Thanks Claymore.
As the car is new to me in the last month I'm going to change the filter, drain then put fresh oil in her and give her some fresh coolant for piece of mind.
Share this post
9 minutes ago, Goldie said:
Thanks Claymore.
Probably best to change the gearbox oil as well. Unless there is a receipt for it being done recently, it's quite often overlooked.
Share this post
A gearbox oil change is a great shout, thank you! And yes, I think every 2k miles sounds like a necessary amount.
Cheers,
Ben
Share this post
