Myself and a friend are hoping to buy a Classic Mini (Hear me out!) and wish to put a 4E-FTE engine inside it...
I have seen tidbits referring to boring out the standard 1.3 cylinders to 1.5. Is this correct? Can you bore out a 4E-FTE to 1500cc?
Any help is appreciated.
hey mate welcome,
in regards to fte'ing a mini its been done quite a few times before in australia
maybe check out our sister site
www.austarletclub.com for ideas as i seam to remember three builds in the past using this car/engine combo
you wouldnt have enough metal to bore out the walls to 1500cc hence y the 5e block was made taller than the 4e block to make the extra cc
Thanks for all your help! I didn't expect such a big response so soon!
*EDIT*
@Enzo: You say it's been done before, but is this using a 4E or 5E? Excuse my n00bishness, but I have no idea if the dimensions are wildly different. SiCaln says the block's taller, but I don't want half the engine poking out of the bonnet! Can you fit a 5E into a Mini, bonnet shut and all that jazz?
it has been done before, there are a few in aus, and theres one floating about in the uk somewhere, i helped the guy out who was building it, but it was a while ago.
also, the 5e is identical to the 4e, except it is 9mm taller.
two fo my favourite cars put together, if only i had known you could do thi when i had mine :) . bet they shift well
