This is the list of modifications either installed, currently being installed, or waiting to be installed, or going to be purchased.
Turbonetics Kit (AEM I/FC + install/tune) BOUGHT (INSTALLED)
# Ceramic Ball Bearing Turbocharger (T3/T4 Hybrid or Custom T04E)
# Spearco Intercooler System
# Powder-Coated Intercooler Piping
# Silicone Hose / T-Bolt Clamps
# Exhaust Manifold - high carbon cast-steel with ceramic coating
# Fuel / Timing Controller (electronic fuel / timing management system)
# Fuel Injectors
# "Evolution" Wastegate Assembly
# "Raptor" By Pass / Blow Off Valve Assembly
# Mandrel-bent ceramic coated Downpipe with closed-loop wastegate discharge
# Intake System with Air Filter
# All necessary Hardware, Hoses, and Fittings
# Free Case of Turbonetics TS-1 Synthetic Motor Oil
Hotchkis Anti-Sway Bar (Front) $299.00 BOUGHT
Hotchkis Anti-Sway Bar (Rear) (included in above price) BOUGHT (INSTALLED)
NST Short Shifter $78 BOUGHT (INSTALLED)
Ingall Rear Shock Brace $150.00 BOUGHT (INSTALLED)
Ingall SS Break Lines $140.00 BOUGHT
Fidanza Aluminum Flywheel $321.97
CarCandy.com: Energy Suspension Polyurethane Motor/Tranny mounts $55 BOUGHT
PowerSlot Rotors (front)
PowerSlot Rotors (Rear)
Axxis Ultimate Brake Pads (Front) $61.00 BOUGHT
Axxis Ultimate Brake Pads (Rear) $54.00 BOUGHT
ATI Center Gauge Pod $110 BOUGHT (INSTALLED)
TRD Black Chrome Front Strut Bar $182 BOUGHT (INSTALLED)
Moshimoto Racing Radiator $230 BOUGHT (INSTALLED)
Dezod: Energy Suspensions Hyper-Flex Master Bushing Set-tC 05+ $185.00 BOUGHT
Dezod: Competition Clutch Stage 3 Clutch Kit-tC 05+ $473.00
TRDsparks.com: TRD Sping/Strut/Shocks $600 BOUGHT
Dezod: NGK Iridium BKR8EIX (2 Steps Colder; Sold Individually) $8.75 x4 BOUGHT (INSTALLED)
Dezod: Front & Rear Anti-Sway bar Endlinks $168 BOUGHT
TRDsparks.com: TRD LSD $1099.00
AEM UEGO Wideband A/F Gauge $272 BOUGHT (INSTALLED)
AEM Tru Boost Controller (ImportSpeedShop.com) $245 BOUGHT (INSTALLED)
Vibrant Vacuum Block (with fittings) $42 BOUGHT (INSTALLED)
Walbaro 255LPH Fuel Pump (W/tC Install kit) $105 BOUGHT
Guage Cluster & HVAC LED/resistor Kit $75 BOUGHT
HKS Turbo Timer Type-1 (US Standard) $116.99 BOUGHT (INSTALLED)
Dr. Isotopes Shifter Bushings $37 BOUGHT (INSTALLED)
3B Specialty HID Kit $145 BOUGHT (INSTALLED)
2008 Scion tC Projector Headlights $200 BOUGHT (INSTALLED)
A.P.T. Foglights $110 BOUGHT (INSTALLED)
Stock form:
I'll post pictures when I get home. Its at the Turbochargers.com shop getting the Turbonetics kit installed and some other things.
There's another build thread here. I just didn't want to clutter up this thread with about... way too many pictures.
lol
I love Starlets and Glanzas. Wish I could import one.
Wallace is right. It's still a Toyota, and as of two days ago, a boosted Toyota.
It's packing a 2.4L VVT-i 4cyl 160bhp/165tqft. I had it dyno'd stock at 140whp/150ftlb atw.
That's the Turbonetics T3/T4 50 trim .48 a/r (watercooled) thats going on the 2AZ-FE.
The Scion tC shares a lot with the Avensis (which you guys do have)...
Rick, when you come down. I'll have to let you go with it... if I have the new clutch in.
  • 1 month later...
Its getting a whole slew of new parts and whatnot right now (cause it's back at Turbochargers.com shop) --
1) TRD Springs (4)
2) TRD Struts (4)
3) HKS Special Edition Turbo Timer
4) ARP Wheel Studs (4 sets of 5)
5) RBF DOT 4 Racing Brake Fluid (2 bottles)
6) Open ended Lug Nuts (4 sets of 5)
7) PowerSlot Rotors (Front & Rear sets)
8 ) Ingalls SS brake lines (Front & Rear sets)
9) TechnaFit SS Clutch line
10) Dezod Endlinks (Front & Rear sets)
11) Front Hotckis Anti-Sway bar
12) Axxis Ultimate Brake pads (Front & Rear sets)
13) Energy Suspension Master Bushing Kit
14) Energy Suspension Motor/Trans Bushing Kit
15) Gates Low-Temp Thermostat
16) Competition Clutch Stage 2
17) Competition Clutch 12 lb. flywheel
  • 1 month later...
All modifications are on hold until further notice (i.e. buying new parts). You would too if you lost your job ;)
I still have parts that need to be installed that I purchased some time ago. One of those was a Gauge & HVAC cluster LED kit. I and the North Houston Scikotics (some of them) got after it yesterday. None of us had done the HVAC before so it took quite a while to double-and-triple check/test that all the resistors and LEDs were done correctly and for me to finally decide what I wanted to do with the colors. I'm mostly satisfied with how it turned out. I need to de-paint the needles completely and leave them clear, and maybe change the blinkers to white... but that's about it. Otherwise, I'm satisfied with how it turned out. Take a look:
the speedo looks really good mate, its got a subtle glow that doesnt over power its self with light (so its blurred and you cant see)
really liking that! ;)
Thanks. In most of the gauges that have been done on tCs, you see a blue/white combo like this:
or one solid color like this:
I wanted something different. It turned out well. The blue to left and right of the speedo make it look even better.
luvly work mate, the soldering looks painstaking, thanx for sharing with us pics of your scion
what model is the engine code?
  • 1 month later...
It's a 2AZ-FE.
As a temporary fix until I get my pieces (manifold/exhaust housing on turbo) for coating I was thinking about getting a Turbo Blanket. They are a bit pricey, but a functional and can provide an additional clean look to the turbo.
The PTP Blanket in black is what I am eye balling currently.
So I got it in. It doesn't like to bend, so I took off the DP. Here is the pictorial results of that.
And there ya go. I'll take it out during the day tomorrow to see what kind of temps I see in the rad. fluid.
thats amazing lol
its the 2.4 litre engine that comes in the avensis i bet this car is fast because i no the avensis's arnt to bad so can imagine what there like with a turbo on
well done mate!
tim
