ste91 Posted August 30, 2009 Posted August 30, 2009 A few months ago I needed new tyres for the front, so after having Proxes T1S I decided to try the T1R.At £45 per tyre (including delivery) they are a very good tyre for the money.The first difference I noticed immediately other than the tread pattern was the softer compound.Here is the difference in tread pattern first the T1S and then the T1R:As you can see the "V" shapes don't go all the way to the end on the T1R whereas they do on the T1S.When driving there is a better "turn in" feeling with the T1R, it feels like they don't flex as much and they felt more grippy (the soft compound is probably the main reason for this). In the wet they were quite good, you just need to be careful when booting it round corners but as far as I can see it's the same case for most tyres.On a good dry day they are excellent tyres, very confidence inspiring and you get a nice squeal to let you know when you're nearing the limit. I would say they're probably good for "occasional track day use" but don't expect them to last too long if you're pushing it.Now the bad part, the downfall of these tyres is how quickly they wear down. I have had them for about 4 months and they are already on the verge of needing to be replaced. I do drive hard and I drive my car pretty much every day but even at that I would have liked them to last a bit longer, I would definately get these tyres again but I'm considering trying a different tyre, maybe the R1R.To sum it up -Dry grip: excellentWet grip: good, unless there has been very heavy rainCost: good value for moneyWear rate: not very good Quote
Liam_D Posted August 30, 2009 Posted August 30, 2009 Good little write-up matey, T1Rs are awesome tyres. Grippy tyres are always gonna wear down very quickly, because there not built to last. Quote
ecksjay Posted August 30, 2009 Posted August 30, 2009 they're a decent road tyre, if you're gonna be going on track at any point then definately look at hankook rs2's, they make t1r's look like shit in comparison.if you drive mainly on road and just need a decent priced road tyre then yeah, t1r's are very good Quote
ste91 Posted August 30, 2009 Author Posted August 30, 2009 how fucking annoying that I write this then find a piece of metal that looks like a big staple in one of the tyres Quote
StarletRick Posted August 31, 2009 Posted August 31, 2009 ive recently changed from toyo's after a LONG relationship with them.they changed the compound a while back and they are just not as good as they used to be ;[ moved over to rainsport 2's now, and they are pretty lush. that said, toyo's are such good value for money. Quote
Russleh Posted August 31, 2009 Posted August 31, 2009 think ill be changing to these after i get new wheels. decided on parada spec 2s last time and i know it said the wet grip isnt very good but its actually quite shocking. spins and slides all over the place. t1rs next Quote
l1 jev Posted August 31, 2009 Posted August 31, 2009 steve my friend where did you get them from mate i need some new tyres mate do you think i will be able to get away with 205's on my glanza mate sound steve Quote
minxy Posted September 2, 2009 Posted September 2, 2009 you can get T1r's 195/45/15 on camskill.com for about £45 each not sure about other sizes and you'll need to get them fitted Quote
Glanza_cl Posted September 2, 2009 Posted September 2, 2009 blackcircles are good plus they do member discount i think? might be tgtt they have the discount code for... but either way cheap Quote
