glanza179 Posted September 17, 2009 Posted September 17, 2009 What sort of boost can i run on a glanza S if i was to just bolt a Hybrid CT9 on if i was to leave the block standard and high compresionJim Quote
bucketep91 Posted September 17, 2009 Posted September 17, 2009 What sort of boost can i run on a glanza S if i was to just bolt a Hybrid CT9 on if i was to leave the block standard and high compresionJimglanza s is a non turbo mate Quote
glanza179 Posted September 17, 2009 Author Posted September 17, 2009 i know ive owned the car for a few months im enquiring to see if the block can take a turbo at low boost rather than fitting a 4eftejim Quote
Starlet__SR Posted September 17, 2009 Posted September 17, 2009 It'd be waste of time with the amount of boost you'd be able to run, you'd only get bored, run more boost and kill it, just fit a turbo.Damien Quote
bucketep91 Posted September 17, 2009 Posted September 17, 2009 mate it will blow up are you mad Quote
glanza179 Posted September 17, 2009 Author Posted September 17, 2009 i have a little more self control than to just turn the boost up. Quote
ToyotaTech15 Posted September 17, 2009 Posted September 17, 2009 Itl just be a waste of time without the low compression pistons, you could run any boost atol as the whole idea of a turbo is to get as much air into the cylinders as possible, if the pistons are still high compression it will just blow head gaskets and probably more constantly.Unless you fit a really thick head gasket to take the compression down to the standard 4EFTE ratio, plus all the other studd involved, it it was me i would just fit a 4EFTE lumpGary Quote
Starlet__SR Posted September 17, 2009 Posted September 17, 2009 i have a little more self control than to just turn the boost up.I said that about my last car, till I ended up running 1.4 bar, which in the end, forced me to go forged:)Damien Quote
RobSR Posted September 17, 2009 Posted September 17, 2009 mate it will blow up are you madit won't if done properly.. There's a td04 ep91 in aus that had the convo done, and it was running 12 sec 1/4's I believe.Nothing wrong with the compression either which is why the afore mentioned one was so quick. Because of the high compression you make more power at lower boost levels. I'll try and find a link.. Quote
glanza179 Posted September 17, 2009 Author Posted September 17, 2009 thanks rob would make some interesting reading, Jim Quote
Driver Posted September 17, 2009 Posted September 17, 2009 standard turbo setup on a normal 4efe at the standard 0.6 bar with emb or similar to make sure fueling is spot on and it will do more power the a glanza/gt as comps higher so less space to fill providing done right will be quick and reliable allthough H/G will prob go at anything over0.5-0.6 Quote
rmsnoel Posted November 11, 2009 Posted November 11, 2009 Just fit 4efte engine, turbo and ecu and sell the glanza S engine and ecu. You'll get more for the glanza S stuff. Its easy turbo conversion cause you already have the looms and stuff in, like inlet manifold is all the same. Every cheaper to fit a turbo engine than turbo your 4efe. You have a glanza with NA pistons exhaust mani and ecu really. Quote
