adee-ep Posted November 8, 2009 Posted November 8, 2009 hi, i have just got a 5efe and used my 4efte head on the block as you do. i got it sitting in and i wired everything up, went to start it and the starter clicked, thought no battery so i jumped it and it still done the same. thought the starter teeth maybe wernt lined up on the flywheel so i took the starter of and tried turning the engine over at the crank but it wouldnt budge. at this point it got a bit worried. i checked the timing again and that was all good. im now thinking its something to do with the gearbox as i should have mentioned its a auto. is there anything that i should have swaped off the 4efte block onto the 5efe block that the auto box needs as the 5efe was a manual apart from the fly and the clutch like thing. cheers any help would be great dont want to have to take the gearbox off again if its not that. Quote
clarkie Posted November 9, 2009 Posted November 9, 2009 hi, i have just got a 5efe and used my 4efte head on the block as you do. i got it sitting in and i wired everything up, went to start it and the starter clicked, thought no battery so i jumped it and it still done the same. thought the starter teeth maybe wernt lined up on the flywheel so i took the starter of and tried turning the engine over at the crank but it wouldnt budge. at this point it got a bit worried. i checked the timing again and that was all good. im now thinking its something to do with the gearbox as i should have mentioned its a auto. is there anything that i should have swaped off the 4efte block onto the 5efe block that the auto box needs as the 5efe was a manual apart from the fly and the clutch like thing. cheers any help would be great dont want to have to take the gearbox off again if its not that.try 1) wier on the starter or2) your earths sounds like a problem ive had before Quote
adee-ep Posted November 9, 2009 Author Posted November 9, 2009 try 1) wier on the starter or2) your earths sounds like a problem ive had before the wire on the starter is fine and its all earthed up. the problem is it wont even turn over by hand at the crank. Quote
nutnut Posted November 9, 2009 Posted November 9, 2009 Check out this postThis postI think its the same prob that you have. Quote
adee-ep Posted November 9, 2009 Author Posted November 9, 2009 Check out this postThis postI think its the same prob that you have.ill go take a look mate i hope it is cheers Quote
adee-ep Posted November 9, 2009 Author Posted November 9, 2009 ill go take a look mate i hope it is cheersive looked over it and ill give that a shot tommorow but mines is a auto and im sure all the plugs are plugged in. my strater was giving a clicking noise and geo said his wasnt. hopefully this is the problem but surely it wouldnt stop it being turned over at the crank.heres what geo found to be wrong with his "Ive used an Auto loom in my manual conversion and what you are getting is exactly what i got before I bridged the selector loom that would usually go into the auto box. Its the 2 thickess wires going into the connector that you bridge from memory. Im pretty sure from a wiring point of view thats all that is required to get the Auto loom to work in a manual.Let me know if you gan get it to idle ok, mines 1500rpm when cold."anymore help or suggestions and ill get too it tomoro people. cheers Quote
StarletRick Posted November 9, 2009 Posted November 9, 2009 earthing. you havent done it properly. stick a jump lead on the negative of the battery and then only the block. i bet it starts.if that isnt it and it wont even turn by hand... then youll have to pull the motor and see what it is. have you done anything to the bottom end on the 5e? rebuilt it or anything? Quote
adee-ep Posted November 9, 2009 Author Posted November 9, 2009 earthing. you havent done it properly. stick a jump lead on the negative of the battery and then only the block. i bet it starts.if that isnt it and it wont even turn by hand... then youll have to pull the motor and see what it is. have you done anything to the bottom end on the 5e? rebuilt it or anything?why wouldnt it turn over by hand if it wasnt earther properly? its just a standard 5efe block with a thicker headgasket and the 4efte head. it turned over fine before i put it in this was with the gearbox off so im thinking its something to do with the gearbox . i just hope its something simple. Quote
adee-ep Posted November 9, 2009 Author Posted November 9, 2009 heres the questions i need anwsered i know it cant be earths because i cant turn t over by hand at the crank something is stopping it.1) is there any sensors that could stop the crank being turned if they are not connected? 2) could it be the auto box cause its onto a manual block. the engine turned over fine before i put the box on and the only time i tried turning it over afer that was when it was in the car .i really think its something to do with the box but i dont want to go and have to take it out agian! cheers Quote
StarletRick Posted November 9, 2009 Posted November 9, 2009 there is nothing that stops the crank from spinning due to sensors etc. i have a few suggestions though. did you use the torque converter with the proper flywheel when you fitted the autobox? is the cam timing done properly? Quote
ToyotaTech15 Posted November 9, 2009 Posted November 9, 2009 Your ep was an auto when it was a 4e block,If you used the flywheel and torque converter etc. Is that not different from the 4e,Could just be locking up because of thatGary Quote
StarletRick Posted November 9, 2009 Posted November 9, 2009 yup, thats where im trying to point the discussion. im sure itll be something to do with the fly/converter. Quote
ToyotaTech15 Posted November 9, 2009 Posted November 9, 2009 Sounds like a gearbox out job thenGary Quote
StarletRick Posted November 9, 2009 Posted November 9, 2009 dont count your chickens yet. might be something simple Quote
adee-ep Posted November 9, 2009 Author Posted November 9, 2009 well cause i couldnt turn the crank to lossen the bolts on the torque convertor and you can move the gearbox over enough i had to drop the engine aswell agian . twice in two days. toke the gearbox of and found the crank turned fine. also found that the block is cracked at eh back . think i hadnt lined the spline up proberly on the gearbox and when i pulled the bolts threw onto the block i have cracked it. nightmare! so its a crankout job and out the crank back into my old 4efte block. hopefully have it running by the weekend. Quote
enzo_e492901 Posted November 9, 2009 Posted November 9, 2009 5E crank wont fit in 4E block due to the longer stroke.Gav Quote
adee-ep Posted November 14, 2009 Author Posted November 14, 2009 took the box off and put the torque convertor in the box and fitted it back together. it now turns over but wont start. it started the first time i tried it but i hasnt started since. any clues? cheers Quote
rmsnoel Posted November 14, 2009 Posted November 14, 2009 Remember the 5efe flywheel is smaller than the 4efte one so you need to use the 5efe starter motor Quote
adee-ep Posted November 14, 2009 Author Posted November 14, 2009 im using the 4efte one redrilled. it has spark and fuel. could the ignition timing be out and stop it starting? also what about the tps could this stop it from starting if its out? cheers Quote
TRD Posted November 14, 2009 Posted November 14, 2009 anyone in desperate need ha Hmmm. What about that small plastic thing in the ignition barrel which was a common fault in toyotas.Keep switching on and off hard on the key for about 5 mins and see if it starts. Mine did the same back in the days,everything lights up and when try to start,just the click.But i had a manual one so push started it,then put back in the drive and tried again switching on and off.Sometimes it would start and sometimes not.Earthing was good,starter motor fine. The fault was in the ignition barrel.Hope it helps. Quote
adee-ep Posted November 14, 2009 Author Posted November 14, 2009 the engines turning but not starting. Quote
TRD Posted November 14, 2009 Posted November 14, 2009 the engines turning but not starting.Put the key in and keep turning from left to right until it starts!!! Quote
Steve GT Posted November 14, 2009 Posted November 14, 2009 might be wrong but its not the starter motor is it or earths on it etc? just an idea lol Quote
