shaneyb Posted December 23, 2009 Posted December 23, 2009 Can I just buy V disks and pads and slap them onto my non abs N/A uk spec? Or do I need to change the calipers aswell? Quote
Amjad Posted December 23, 2009 Posted December 23, 2009 I think the calipers are a little bigger on the V bro, not 100% sure, but someone will confirm soon enough Quote
DavidAshton Posted December 23, 2009 Posted December 23, 2009 Yeah 100% need V calipers. V disks are bigger than n/a so n/a calipers dont accept them. CRAIG-SR did the swap and was pleased with the results. Quote
shaneyb Posted December 23, 2009 Author Posted December 23, 2009 Thank you lads. This will go on my to do list. Can anyone recommend disks and pads? Nothing 2 pricey as my N/A is not going to set the world alight . Quote
LukeSR Posted December 23, 2009 Posted December 23, 2009 N/A brakes are made of fucking cheese ! Quote
DavidAshton Posted December 23, 2009 Posted December 23, 2009 If your going to do the glanza conversion i cant fault thesehttp://cgi.ebay.co.uk/GLANZA-TURBO-GROOVED...=item2a03398be5 Quote
shaneyb Posted December 23, 2009 Author Posted December 23, 2009 I like the look of those! Doesn't say if they are abs or non abs fitment though? Quote
Russleh Posted December 23, 2009 Posted December 23, 2009 arent the sr brakes the same as the brakes from a v. i know the sportif has tiny tiny calipers on it though Quote
DavidAshton Posted December 23, 2009 Posted December 23, 2009 Dont think it makes a difference, the abs system is not on the disk as far as im aware SR brakes are not the same as a V, CRAIG-SR tried to fit them onto SR calipers with no sucess. Quote
shaneyb Posted December 23, 2009 Author Posted December 23, 2009 One more question.Will braided brake lines made for a V fit? Quote
DavidAshton Posted December 23, 2009 Posted December 23, 2009 I believe so, ill double check with Craig as he fitted braded lines to his SR / Glanza front brakes. I think you end up with the rears too which cant be fitted though. Quote
Russleh Posted December 23, 2009 Posted December 23, 2009 hmm sure mine has sr brakes according to the build thread when greame changed the brakes and i just fitted the td brake kit with no issues. Quote
CRAIG-SR Posted December 23, 2009 Posted December 23, 2009 You will need glanza calipers on and the braided line will fit too. I have Do-Luck lines and it said they are for a ep91. I couldnt get the SR caliper over my grooved disc. Quote
Russleh Posted December 23, 2009 Posted December 23, 2009 hmm i checked streetracer_starlets old build thread for my white car and it was sr brakes that were on it but they were red so i dunno if at somepoint they were changed again for the ones off a v. all i know is i fitted the discs with no probs. Quote
shaneyb Posted December 23, 2009 Author Posted December 23, 2009 Cheers lads.Craig - Hows the braking power? Big improvement? Do you have abs?David - I can fit the rear lines if I do an axle conversion right? Quote
Guest Enzo Posted December 23, 2009 Posted December 23, 2009 dependant on what year of starlet you have, the ep91 have the same sized braking setup at the front as the glanza v.some early sportifs had the smaller braking setup. Quote
Nanglebadger Posted December 23, 2009 Posted December 23, 2009 Mine's a 1998 and came with the same brakes as the Vs!Phil. Quote
Asad Posted December 23, 2009 Posted December 23, 2009 Im guessing my 96 P reg CD model has the smaller variant of brakes?? Quote
shaneyb Posted December 23, 2009 Author Posted December 23, 2009 Mines a 98. If V brakes fit on mine then im going to be one happy man! That means braided hoses will fit straight on aswell?Mine's a 1998 and came with the same brakes as the Vs!Phil.Abs or non Abs? Quote
shaneyb Posted December 23, 2009 Author Posted December 23, 2009 When you have a minute could you check on your logbook when you car was registered? So I know if its the same time as mine then I should have the same brake set up. Also is yours an sr or sportif? Quote
Nanglebadger Posted December 23, 2009 Posted December 23, 2009 neither, Solida.Metallic Paint, central locking, colour coded mirrors and door handles, etc etc.First registered: 30/06/1998Phil. Quote
shaneyb Posted December 23, 2009 Author Posted December 23, 2009 Cheers bud. Just realised Craigs n/a is a T reg so is newer then both of ours and glanza disks did not fit. hmmm. Quote
Nanglebadger Posted December 23, 2009 Posted December 23, 2009 well i have a set of 3G discs off a GT on mine, so, yeah lol, figure that one out!Phil. Quote
CRAIG-SR Posted December 23, 2009 Posted December 23, 2009 It is strange like, But the lad who did mine said the caliper would not fit right. Quote
