Glanza_Lee Posted January 29, 2010 Share Posted January 29, 2010 Hi all. I am in the process of removing my instrument cluster out of my Glanza. I removed the black casing around the cluster held on with two philips screws. Then I removed the three screws holding the cluster to the dash. I now need to remove the three plugs behind the cluster, I took one off but cant do the other two as they are pretty tight. I wanted to see if the cluster would pull out a bit more for me to get better access to the plugs but it feels like there is still something holding it on. Are there any other screws holding it together? Thanks in advance, Lee. Quote Link to post Share on other sites
Nanglebadger Posted January 29, 2010 Share Posted January 29, 2010 two or three plugs mate yes, and the speedo cable. until these are released there isn't really much give tbh.its a wanker of a job, thats why i let my bro do it lol!Phil. Quote Link to post Share on other sites
Glanza_Lee Posted January 29, 2010 Author Share Posted January 29, 2010 Ha, i know! It's not easy! I managed to get the top three plugs out, just the speedo cable now. How does it come out? Do you have to twist it or something? I'm going to finish it in the morning as I was getting frustrated with it! lol! Quote Link to post Share on other sites
Glanza_Lee Posted January 30, 2010 Author Share Posted January 30, 2010 Is anyone able to tell me wether you have to twist the speedo cable to get it out or does it just pull out? Quote Link to post Share on other sites
micky boy Posted January 30, 2010 Share Posted January 30, 2010 It has clips on it mate squeeze and pull at the same time its a right slut lol Quote Link to post Share on other sites
Glanza_Lee Posted January 30, 2010 Author Share Posted January 30, 2010 Lol, tell me about it! Makes it twice as hard when you cant see what your doing! Thanks mate! Quote Link to post Share on other sites
micky boy Posted January 30, 2010 Share Posted January 30, 2010 lol i know how you feel mate the best part is I've got to do mine tomorrow i have some light out on my cluster so your not going to be the only one thats going to be pissed off Quote Link to post Share on other sites
Glanza_Lee Posted January 30, 2010 Author Share Posted January 30, 2010 Well lets hope you get further than what I have. I still cant get it out! It's driving me mad! Could you do me a huge favour and maybe post a pic of the back of your cluster once you have got it out? Just so I can see whereabouts the speedo cable plugs into. I must have been near as I moved something and the needle on the speedo moved a bit. If you could do that for me mate I would really appreciate it. Regards, Lee. Quote Link to post Share on other sites
Glanza_Lee Posted January 30, 2010 Author Share Posted January 30, 2010 I was just thinking. I only want to see if the standard 180 dials are behind the dials that are fitted now. Am I able to do this with the cluster still in? Would I just have to remove the clear plastuc part, remove speedo needle and undo the two little black screws on the dial to see whats behind it? Quote Link to post Share on other sites
micky boy Posted January 30, 2010 Share Posted January 30, 2010 If i pull mine out tomorrow if this snow fucks off i,ll take some pics buddy,its better to remove the full cluster by the time you mess about trying to take the plastic off the front you could of removed the full cluster lol if you move the steering wheel all the way down as far as it will go it will give you more room for you hand to get in, stop pissing around squeeze and pull on the fucker not to hard though Quote Link to post Share on other sites
Ryan5793 Posted January 30, 2010 Share Posted January 30, 2010 when i changed my dials, i took the steering wheel off, the dial surround thing and the plastic underneath the steering wheel, so you could get your hand up from behind. then left my dad to do the rest should be 3 plugs and the speedo cable which is a pain I've been told Quote Link to post Share on other sites
WallaceGlanza Posted January 30, 2010 Share Posted January 30, 2010 I was just thinking. I only want to see if the standard 180 dials are behind the dials that are fitted now. Am I able to do this with the cluster still in? Would I just have to remove the clear plastuc part, remove speedo needle and undo the two little black screws on the dial to see whats behind it?Yes, you don't need to take the whole cluster out to change the dial face.Just to make you feel bad I just removed mine half an hour ago, I find it a piece of piss to remove.The speedo cable just pulls straight out, it's actually the easiest to remove, just squeeze the clip and pull, it's right in the middle exactly in line with the speedo needle. Quote Link to post Share on other sites
Glanza_Lee Posted January 30, 2010 Author Share Posted January 30, 2010 I dont need to use the car now so i'm gonna give it another go. This time, I will get it off! Quote Link to post Share on other sites
Glanza_Lee Posted January 30, 2010 Author Share Posted January 30, 2010 Well now I know the standard 180 dials are not behind the 110 dials that are fitted now. I didnt take the cluster out, instead I took out the clear plastic cover in front of the dials and peeled the dials back a little so I could see. Now i'm looking for just the 180 Glanza dials. I'll post a topic in the wanted section but if anyone here has any, please let me know. Regards, Lee. Quote Link to post Share on other sites
OzGlanzaV Posted February 6, 2010 Share Posted February 6, 2010 Hahaha,Just tried to do this myself.Do I need to remove the cluster to change the bulbs behind the speedo?Also, does anyone know what bulbs I need? Its the one that lights up the left hand side of the speedo.Someone should do a how too to get the cluster out, I found there was a bit of play to pull it out a couple of inches, but couldnt get to the looms.Cheers,Oz Quote Link to post Share on other sites
WallaceGlanza Posted February 6, 2010 Share Posted February 6, 2010 Hahaha,Just tried to do this myself.Do I need to remove the cluster to change the bulbs behind the speedo?Also, does anyone know what bulbs I need? Its the one that lights up the left hand side of the speedo.Someone should do a how too to get the cluster out, I found there was a bit of play to pull it out a couple of inches, but couldnt get to the looms.Cheers,OzYes you'll need to take the cluster out to change the bulbs. A "how to" wouldn't really help as the hard part is just getting your hands in the back to remove the speedo cable and electrical connections, there's not really a trick to it you just need to feel what you're doing.There is three elctrical plug connectors one at either side and one in the middle - all at the top, you need to press the clip on them then pull at the same time and they will come out (one at a time obviously), the speedo cable is the same. Quote Link to post Share on other sites
OzGlanzaV Posted February 6, 2010 Share Posted February 6, 2010 Ok cheers mate.Dont suppose you know what bulb Id need?Thanks.Oz Quote Link to post Share on other sites
