joel_ep91 Posted February 13, 2010 Posted February 13, 2010 ok does the corolla mani actualy make any power gains to the 4efe was told on tgtt that it is just a myth and better not wasting my cash .has anyone actualy got any proff that the mani give more gains or is it actualy a myth.any info would be helpfulthanks joel Quote
lukEp Posted February 13, 2010 Posted February 13, 2010 well craig_n glanza s came with the mani on as standard i think and hes making 93ish bhp at the flywheel so id say it makes a difference. Quote
joel_ep91 Posted February 13, 2010 Author Posted February 13, 2010 i might be better off with what i have then as i made 92 bhp at the wheels that was with ep95 mani injectors and full exhaust system Quote
ste91 Posted February 13, 2010 Posted February 13, 2010 EP95 mani should be the same as the Corolla one?And I'd like to know which numpty told you there was no gains with the Corolla manifold. ;) Quote
joel_ep91 Posted February 13, 2010 Author Posted February 13, 2010 EP95 mani should be the same as the Corolla one?And I'd like to know which numpty told you there was no gains with the Corolla manifold. ;)the ep95 (4x4starlet) mani looks the same as the fte mani but without the sensors and vac lines for the turbo.a guy fatman what i said.i was told they are quite good compared to the standard 4efe starlet manifoldswhat he said.(Most certainly a myth. Testing showed significant gains across the board bolting on a 4e-fte manifold.5e-fhe ACIS manifold is the best option by a long way, especially if you can rig the ACIS mechanism to switch at the right time. Genuine gains to be had, turbo and NA.) Quote
micky boy Posted February 13, 2010 Posted February 13, 2010 I dont know much about n/a starlet's but i've heard that the Glanza s has a more aggressive ECU? im not sure if that helps the power on the S or not I've also heard that the corolla bug eye has biger injectors so that will help with power Quote
ste91 Posted February 13, 2010 Posted February 13, 2010 the ep95 (4x4starlet) mani looks the same as the fte mani but without the sensors and vac lines for the turbo.a guy fatman what i said.i was told they are quite good compared to the standard 4efe starlet manifoldswhat he said.(Most certainly a myth. Testing showed significant gains across the board bolting on a 4e-fte manifold.5e-fhe ACIS manifold is the best option by a long way, especially if you can rig the ACIS mechanism to switch at the right time. Genuine gains to be had, turbo and NA.)That's wrong;The EP95 has the same manifold as the Glanza S/Corolla.The earlier EP85 has the 1st gen 4EFE which has the same manifold as the 4EFTE.When you posted this on TGTT did you specify that it was for the N/A and not turbo, as they are mostly turbos over there, and the manifold from the Glanza S/Corolla isn't great on a 4EFTE. Quote
joel_ep91 Posted February 13, 2010 Author Posted February 13, 2010 my bad its the ep85 mani i have sorry .yea i said that it was for my n/a frig dont know what to do Quote
Craig_N Posted February 13, 2010 Posted February 13, 2010 Just give it a try matey if you dont think its an advantage then change it back ;) Quote
Amjad Posted February 14, 2010 Posted February 14, 2010 Joel it sounds like you got a good result on the dyno! Do you have a Decat or just a Cat-Back exhaust system?And as Craig said why not try it out Quote
krissman Posted April 13, 2010 Posted April 13, 2010 Hello everyone!I'm new here on Ukstarletclub. A great site by the way.I'm a 22 years old student living in Lillehammer, Norway. I am currently in the process of buying a starlet 1997 modell. Therefore I've been doing a lot of research about what can be done to give the 75 hp starlet engine a bit more power, just to make the car a bit more fun. From what I've found, it seems like the mod that gives the most bang for buck is the switch to the corolla (86hp) intake manifold. I've read that a lot of people have done this and say it helps a lot. However, I have yet to see someone switch to Corolla ECU from the same corolla engine... As far as I know, the only differences between the 75 hp starlet and the 86 hp corolla is the manifold and the ECU. If so then you could have an 11 hp increase, and a 5 nm increase for almost no work at all... Has anyone here tried this out? Also... Is it difficult to change the manifold and ECU? Maybe someone could compose a guide? Quote
