  • Replies 74
  • Created
  • Last Reply
Top Posters In This Topic
If you are a man with money get a HKS adjustable actuator and a front mount intercooler (worth it in the long run anyway) will narrow down the problem.
Joe
Joe
I have a front mount intercooler.
First turbo stopped working
Got another actuator still didn't work
Second turbo & another actuator
Still not working !!
Thats where im puzzled on this
I know it sounds annoying but might be worth taking apart the front mount and checking each part of the kit mate
Joe
chwck for what !!
all joints are tight
tears in the silicone hosing or nicks/dents in the hard piping.
If you have your original topmount intercooler you could put this back on quickly to check if its intercooler based or turbo based.
Just tryin to help mate, i had the same problem a while ago and my exhaust was ridiculously loud becuase the circ-clip came off the actuator and had no boost whatsoever!
Joe
checked all the intercooler pipe joints no splits anywhere/
Circlip is on the actuator.
I was revving the car & manully opening the wastegate with a long screwdriver to see if the turbo will spool but nothing.
I do appreciate the help.
Can i ask a question for my own knowledge.
What does the Circ clip do?
Where is it located?
The circlip is on the pin that stop the actuator falling of the wastegate.
Look down the front of your manifold & you will see the small clip.
right, i have no idea what im on about, but no one was asked this and its worth a try. is the FMIC ok?
A stone could have periced it causing a leak therefore no boost? like i said i have on idea what im on about.
hope it get sorted soon,
Checked & no damage
Still no boost.
Good idea thiough
have u got any form of boost controller or bleed valve? its got to be somthing silly. maybe the boost has somehow been turned down,u said it goes to about 2 psi? does it hold there or drop back off? either that or u have been very unlucky with buying fucked parts ie actuators and turbo
Tried with & without aftermarket boost controller
Factory boost solinoid has already been bypassed
run the vac pipe from the actuator straight to the nipple on the turbo. what boost do you get then?
What nipple on the actuator are you on about
as the turbo is connected to the nipple on the top of the actuator
the nipple on the back is connected to the EFI pipe
On the stock actuator there is two prongs... one vacuum pipe come's off the turbo then to the actuator....The other prong go's to the EFI pipe/ 1st 2nd...boost solenoid....Try blocking that off.. if you are useing the stock actuator....It sounds like the actuator arm isnt pushing the wastgate flap open enuf
Found a small crack in the intercooler pipe ( damn speedhumps )
Replaced it & now i have boost :lol:
Thank you all for the advice given
Was on the verge of stripping the car for parts & starting a fresh with another V.
Will be going for a nice blast soon & enjoy my boost.
its always somthing silly like that glad u got to the bottom of it dude. but your a plank for not noticing it :lol:
only joking dude!
I feel a plank to be honest
Have been checking everything from above .
Was only when i was sitting on the floor thinking about how much i sell this & that for ,
I could hear a slight hiss noise
