wat is the best way for me to get negative camber on the rear of my V
dont want alot just enought so it is visable
this is purely for looks rather then anything else
cheers guys in advance
Yeah as said you cant do it to the rear of Starlets, only the two fronts which is a bit gay.
Just need to bring it to me and ill put some negative camberage on her for you :)
We dont fit them dude unfortanely, we just set them up to any settings you want really.
Camber is £15 a side normally and then £39.95 for the toe, but you get UKSC discount so it'll be whatever my boss decides lol.
like the front tires, camber and toe-in can be used to help the rear tires perform to thier maximum potentential. A tire delivers its maximum cornering power when it has a slight amount of negative camber in reference to the ground . some of this is the result of the bending of the hubs , axle and control arms.
also toe in at the rear axle is a stabilizing effect , and toe out can cause the car to over steer under acceleration so you want to make sure this never happens wen bendind the axle, hubs.
because a solid rear axle can flex, it will often toe out under braking and toe-in under acceleration. which is normally a good situation.
ahh is it more bennaficial to rwd cars rather than fwd?
seems abit pointless for a roadcar tbh...... but dose look cool I've gotta say :p
this is very true rear wheel drive is fun fun fun. :)
Negative camber is used so that when the car corners and rolls toward the offside of the corner, the negatively cambered wheel/s will then effectively be at 0 degrees. Because of this there will be more rubber on the road which = more friction. More friction equals faster corning :). But obvz when the car isnt taking a corner or banking the wheels will have negative camber, wearing the insides of the tyres. To what extent depends on the angle's.
Get coilovers dude with adjustable top mounts.
Mitch
