starting with an rx7 tmic what would be the best and most efficient way to reach that sort of power? ive all ready taken care of the handling and breaking so now its time to move on to power.
my mods so far are
straight through exhaust
BOV
iradium spark plugs
cheers Danny
You can get that sort of power @ 12psi on the CT9 but you will want to port the wastegate to reduce boost creep.
As already mentioned, exhaust manifold and decat, air filter, adjustable actuator (turn it up to 11-12 psi, but remember fuel cut is at 12.5 psi so any bit of creep and you will be hitting it).
It is possible to get 160ish bhp without touching the ECU but it's advisable to atleast get a piggyback such as Emanage Blue to make the most of it, and once you go past this point in power you'll need to upgrade the fuel management anyway so it's worth getting.
Also if you were to upgrade the RX7 TMIC to a good FMIC you could turn the boost up to 1 bar and get around 180bhp on a good remap.
You could hit that at .8 bar matey <_< you wouldn't need to touch the mani, just put a decat on there and an adjustable actuator and a Safc or similar to trim the fuelling. If you get a 2" decat it would hardly creep or even not creep atal aswell so you wouldn't have to worry about porting the turbo.
In an ideal world for you tho you'd want this ontop of what you've got at the min
Mani
Decat
Fmic
Relocated filter
Adjustable actuator
Management (emb or something)
Hit 161 bhp and 184Nm the last time I was on the rolling road.
Only fit a filterrelocation with K&N-filter, ARC-TMIC, zisco-mainfold and a custommade stainlesssteel exaust (2,5").
Everything else is stock on the engine, also the actuator or the boost is untoucht.
