Here We Go Again
Is that Shortys old car? Seen it on track on Japfest 2, looks awesome anyway mate. And the plans sound awesome.
But yeah you wont have it for long :lol:
Guest cheshireglanza
^^ yes dean the lad who owned it said he seen you few times
But yeah you wont have it for long :D
no its not liam, has the same alloys that i did have on mine a year back but my baby is still parked outside :( also saw this at fest though and had a good chat with the lad who tracked it, guess he thrashed it few to many times if he killed the bottom end :D
Ok engine has been fitted but on the way home from td the water pump decided to give in so now i either have head gasket problem or stem seal's
so no when i pull over you cant see the car with smoke but im thinking turbo could be gone has old engine put conrod threw the block ;)
yes had engine swap for gt engine water pump was fine when it left garage then going down motorway temp gauge hit the roof,pulled it over to find water pissing out from pump so hopefully i saved the head gasket
car pull's fine just smoke's loads on idle once it has warmed up
^^ not what i wanted to hear i need the car to look for work ;)
^^ the head on old engine is fooked got fried when conrod come threw block
