corolla 4efte dyno run... (video added)
dyno'd today.....
0.4bar
114bhp @ 5349 revs
115.9 lbft @ 5051 revs
was soooo dissappointed... was hoping for 125ish atleast....
FMIC
japspeed Decat
japspeed exhaust manifold buts its only got 1" exhaust after that
from factory its 135 @ 0.6 bar? right?
also wheres peak power supposed to be on ct9?
is torque supposed to be higher than bhp?
Dyno run
thanks
ishaq
  miib14 said:
dyno'd today.....
0.4bar
114bhp @ 5349 revs
FMIC
japspeed Decat
thanks
ishaq
ther 135 at the fly is your reslut at the wheels or fly and on the 4efte torque is lower its only a small engien
  yaristurbo said:
its low power because?
your running lower boost
really small exhaust
how big is your intercooler piping?
and also what management?
not even gonna mention intercooler becasue its a good one, i had charge temp of 26 degrees c with that one
dunno why its running lower boost,
definetly small exhaust lol
and its all running on standard EP82 GT ecu..
  micky boy said:
I think thats a great result for the mods you've got and takeing into account the miles that are on the engine and the exhause ect? and also i think low boost is 0.6 and hi boost is 0.8 standard
thank you...
so its running lower than low? :)
  lukEp said:
That a good result considering the engine is running less than standard boost
thanks... was just expecting more...
Yep any higher then that and you will hit fuel cut.
Also why we are talkeing about boost this is the best thing i ever brought for my ep its a Zep raceing extra nipple it taps into the inlet manifold for acurate boost readings its worth buying
http://www.rhdjapan.com/catalogsearch/resu...p;x=59&y=13
no stock boost is 6psi low and 9psi high but you wont hit fuel cut till 12psi meaning the ecu can fuel upto 12psi without running lean.
6psi = 0.41 bar
9psi = 0.62 bar
but you will only get the 133bhp on high boost (0.6bar)
so still a good result on just a small amount of boost at this level if you up'd the boost to 0.6bar you will prob see and feel the 15bhp gain
thanks luke...
knew i read something like that before lol...
just got to find some way of running 0.6 now lol
actuator will probz be easiest and best way?
where exactly does that nipple attach to?
  miib14 said:
thanks luke...
Just taps into the inlet its hard to say where abouts will take some pics tomorrow...and yeah the actuator will be the easiest ways to turn the boost up, well thats if you dont have a boost controller lol.
@Amjad i didnt pay tax mate i dont think you have to pay tax if its under a £100? could be rong though but i deffo never paid tax
Edite..Yeah Luke is right
well I've got an gen 2 apexi avcr controller... just not fitted though
but id rather get both fitted...
you paid that much for that which is just acts as a t piece!!
