ali_legend Posted March 14, 2011 Posted March 14, 2011 Hi guys ive asked a few uksc boiz about this but thought id get some more opinions. Was goin to get a new air filter but unsure what to get.? Theres a few choices (for my sportif n/a 98)Either a panel filter and airbox or cone filter.?1. K&n panel filter2. Blitz panel filter3. Some type of cone filterif i went for a panel filter would replacing the efi plastic pipe to aluminium make a diff.? If yes would i need silicone hose to hold the pipe in or.? I know there isnt going to be a big difference but which one would make the biggest performance difference.? Also which would be best economicaly/performance.? Thanks in advance guys Quote
TrisK Posted March 14, 2011 Posted March 14, 2011 on something like a n/a, i would go for a pannel with a nice cold air intake. but thats just me.cones get too much heat soak, especially with the inlet mani at the back like on the n/a. Quote
ali_legend Posted March 14, 2011 Author Posted March 14, 2011 How would i get a cold intake to panel filter pal if its in airbox.? Cheers buddy Quote
TrisK Posted March 14, 2011 Posted March 14, 2011 How would i get a cold intake to panel filter pal if its in airbox.? Cheers buddyopen your airbox up. there will be an oem intake (otherwise where does it get its air from?)replace that with something a bit bigger, and put the other end where there will be a lot of air intake.front grill, fog light, etc etc.a tip ive read before, is copy something from a b series honda engine. as aparently the n/a engines are the same as the b series, just mirrored (but i dont know how true that is). Quote
TrisK Posted March 14, 2011 Posted March 14, 2011 new informationhttp://www.ukstarletclub.com/forums/index....showtopic=35703refer to that topic above, some the n/a boys talking about it.especially listen to amjad, he made some serious power for a 1.3 Quote
wssoR Posted March 14, 2011 Posted March 14, 2011 If you get a decent enough supply of cold air then a cone is better IMO, just look at jamies ep (starlet Sportif) he managed 90bhp on an engine with 120k on it and he's using a cone. Quote
string Posted March 14, 2011 Posted March 14, 2011 panel i'd say. i offered ya that hks one with a air box so you could drill etc and still go back to standard when ya sold and you said no. Quote
Guest Enzo Posted March 14, 2011 Posted March 14, 2011 stock airbox for the win, ul fuck up part throttle responce and little torque low down if you just wap a cone on for the sake of 1+bhp up topso eather standard filament or k&nbmw closed induction kit is the best option all round if you have the cash Quote
Nanglebadger Posted March 14, 2011 Posted March 14, 2011 OEM intake system is full of win as Geo said.leave it alone. fit a K&N panel filter and leave the intake pipe and box be! toyota most likely spent due time and effort on designing it to work appropriately, from chats I've had with Jay, they wont have designed it to be shit. so, maximise on their research and development efforts, fit an uprated panel and be done.also, i think Geo meant BMC closed induction kit, and yes i agree, if u have the funds, the BMC Carbon Dynamic Airbox systems are uber.Phil. Quote
ali_legend Posted March 14, 2011 Author Posted March 14, 2011 Cheers guys.! unfortunately dont have the funds for BMC LOL. so its a k&n/Blitz panel filter Thanks for all your help guyswill these fit;k&nhttp://cgi.ebay.co.uk/K-N-TOYOTA-STARLET-E...16#ht_500wt_949Blitzhttp://cgi.ebay.co.uk/BLITZ-PANEL-FILTER-T...ee#ht_500wt_949 Quote
Jozinobi Posted March 14, 2011 Posted March 14, 2011 They will both fit Ali as stated earlier Turbo panel filter is the exact same fitment as n/a!Joz Quote
The Toffinator Posted March 14, 2011 Posted March 14, 2011 I had a pipercross cone on the standard intake and it lost bottom end and lost part throttle response as people have said, then i went for a BMC copy, (the plastic BMC one) and the difference was alot better, next plan is to order a carbon BMC and put the intake towards the bottom of the bay with the airbox at the top. this should hopefully be the best of both worlds. Quote
ali_legend Posted March 14, 2011 Author Posted March 14, 2011 Sorry joz didnt mean to right will these fit but which ones better Quote
Jozinobi Posted March 14, 2011 Posted March 14, 2011 Sorry joz didnt mean to right will these fit but which ones better There was no need to apologise mate lol Completely your preference, the TRD, Blitz, K&N are all decent.Nobody can really choose for you.Joz Quote
nastyrash 2003 Posted March 15, 2011 Posted March 15, 2011 yep as said above mate, cone filters are a bit of a gimik and cheap 1s do not filter very well either!!. go pannel and drill out the bottom of the air box + cold air feed Quote
ali_legend Posted March 15, 2011 Author Posted March 15, 2011 yep as said above mate, cone filters are a bit of a gimik and cheap 1s do not filter very well either!!. go pannel and drill out the bottom of the air box + cold air feedwhat do ya mean by drill out bottom of airbox + cold air feed pal.? Quote
nastyrash 2003 Posted March 15, 2011 Posted March 15, 2011 get a hole saw for the drill and under the filter part of the box brill holes wer u can get to it from engine bay, thn use flxi air ducting heat resistan stuff, can get it off air conditioning sites, this will bring in cold air from the front of the car direct it at the holes, the key to this is to keep it as short as poss and limmet the bends try to keep thm under 45 deg. try to keep the intake of the feed up off the floor (dirty and damp air!!!). i would use a small bonnet scoop which sits fat like the fiest rs. and direct the cold air in from thr as the bonnet has a large surface area and will supply a nice clean air feed. the civic group m induction kits are a better idea but body fabrication is needed, but not that hard. Quote
