Steve GT Posted March 15, 2011 Posted March 15, 2011 Hello allCars all back together now everythings on........but she's idling very high. about 2200 revs and thats with the bleed screw on the inlet turned all the way round.so anyone have any suggestions to what i can tryim pretty sure its not a vaccum line as there all connected I've gone over them all. im thinking to change map sensor and TPS and see if that does it but just incase thought id ask if anyone on here has anything to try Quote
Sparky Posted March 15, 2011 Posted March 15, 2011 If you have removed all the aircon and rubbish I am sure you need to adjust the idle, possibly that or is that what you mean by you have wound the screw out on the throttle body? Quote
mini valver Posted March 15, 2011 Posted March 15, 2011 you have an air leak mate there is no need to play about with any thing even if you have taken the air con out. wat ever you do dont play about with the tps they are an absalute twat to reset trust me i no. if you want to check that it is the tps disconnect it the car will still run fine. and it wont be the map sensor. it maybe no vacumes could be inlet gaskets throttle body gaskets stuff like that you sure your throttle cable is not to tightgood luck Quote
Socks Posted March 15, 2011 Posted March 15, 2011 just to expand on this...unplugging the icv and tps do NOTHING idle does not change.screw is all the way in wont go anymore...no air leaks i can see ether... Quote
chris H Posted March 15, 2011 Posted March 15, 2011 Sorry to hijack but what screw? i set my timing to 10BTDC and it ticks over at 1250, can't see any leaks either.is the inlet mani gasket on ok/ not damaged? Quote
micky boy Posted March 15, 2011 Posted March 15, 2011 This screw chris its sits on top of the throttle body there will be a round rubber cap covering it over...Also have you tryed another icv just incase yours is fooked steve?Brass screw on the right side Edit.. just read socks post yeah maybe it could be the tps Quote
chris H Posted March 15, 2011 Posted March 15, 2011 Micky my friend i owe you a large beer!!! 30 seconds and the car now ticks over at 750 rpm for the first time since i bought it! lolI didn't even know the screw was there!I'd take the intake pipe off the manifold and see where the butterfly is positioned, i.e fully closed or slightly open, to see what the throttle position is.When you rev it does it take a while for the revs to drop? if the revs take longer than usual to drop it usually points to an air leak, if it's just high tick over i'd say the same as micky, swap the icv over/dismantle yours and see if it's damaged inside. Quote
micky boy Posted March 15, 2011 Posted March 15, 2011 Lol not a problem chris happy to help you will be surprised how many people dont know its there lol Quote
mini valver Posted March 15, 2011 Posted March 15, 2011 nice one mickyhonestly does sound like an air leak especially at them revs. try spraying plus gas or wd40 near all the inlet and stuff like that if it revs up a little more you no it is drawing in air it should not be. it is just a engine and they all work the same. Quote
whiteglanzav Posted March 15, 2011 Posted March 15, 2011 does sound like thers somthing letting excess air in somwhere steve mine did the exact same thing when a vac pipe was missing Quote
Steve GT Posted March 16, 2011 Author Posted March 16, 2011 ok so question is if the inlet gasket is fooked then would that be causing the problem? cause I've checked all pipes on inlet they all sem fine. just thought i put the old inlet gasket back on so this could be the problem Quote
micky boy Posted March 16, 2011 Posted March 16, 2011 Yeah it could be mate, for the sake of £10 for both gaskets its worth trying. Quote
Steve GT Posted March 16, 2011 Author Posted March 16, 2011 nope idling like a bitch lol cant see why either chris lol Quote
rorenapier Posted March 16, 2011 Posted March 16, 2011 You have all the vac pipes plumbed correctly? Quote
Steve GT Posted March 16, 2011 Author Posted March 16, 2011 yep from what i can see everythings in order Quote
string Posted March 16, 2011 Posted March 16, 2011 on your new blitz dv is the adjuster screw in the top. i forgot to put mine in once and took me ages to work out. Quote
Socks Posted March 16, 2011 Posted March 16, 2011 it was doing this before he even fitted the d/v string ive tried putting my finger over all the vaccum inputs/outputs on the inlet... no change!air leak is screaming to me... cus steve didnt put a new inlet to head gasket on! Quote
rorenapier Posted March 16, 2011 Posted March 16, 2011 Metal gaskets can be re-used if cleaned before fitting.Checked the throttle cable tension? Aye make sure it isnt to tight to crack the butterfly open Quote
