Sparky Posted May 24, 2011 Share Posted May 24, 2011 Right I recently rebuilt my engine and from day one both crank seals have leaked!I know lots of people have had the same problem with them so I was just wondering is there a certain way to fit them or any reason why they shit theirselves?By the way they were leaking before the car even seen boost because I had to take it for MOT with no boost pipe so that wasnt the issue.I am also running the stock PCV with a cusco catch can just on the breather and the other port on the catch can venting to atmosphere so dont think thats the problem?Any help or info is greatly appreciated as I will be chaning them again this weekend along with a new A.C.T 6 puck clutch so really need to get it right this time!Thanks Lewis Quote Link to post Share on other sites
lukEp Posted May 24, 2011 Share Posted May 24, 2011 Sometimes the seal will wear the crank down you should be able to feel the grove if it's bad enough to make it not seal Quote Link to post Share on other sites
Sparky Posted May 24, 2011 Author Share Posted May 24, 2011 Fuck I hope its not that, didnt seem bad when we had the crank out Quote Link to post Share on other sites
nastyrash 2003 Posted May 24, 2011 Share Posted May 24, 2011 put som sealant on outside edge + grease on inside seal helps seal mate. Quote Link to post Share on other sites
chris H Posted May 24, 2011 Share Posted May 24, 2011 Might sound daft but i used to work on the production line at nissan and we were told not to touch the oil seals with your bare hands as it fucks them,something to do with the sweat on your hands. Quote Link to post Share on other sites
Bean Posted May 24, 2011 Share Posted May 24, 2011 did you not use new ones when you rebuilt the engine?? Quote Link to post Share on other sites
nastyrash 2003 Posted May 25, 2011 Share Posted May 25, 2011 u can get proper seal kitting tools or use black tap on the crank. having the same problem fella. just think thr cheap seals. u should have seen a toyota head gasket fit on the block deck, it was shocking, but same as the cheap after market. makes me think its all in the pakaging Quote Link to post Share on other sites
enzo_e492901 Posted May 25, 2011 Share Posted May 25, 2011 As other people have said somewhere above, it will more than likely be the grooves that have been worn into the crank.Gavin Quote Link to post Share on other sites
turbo Grant Posted May 25, 2011 Share Posted May 25, 2011 Use lots of grease when fitting then. A dry seal will burn out in no time! Quote Link to post Share on other sites
Sparky Posted May 25, 2011 Author Share Posted May 25, 2011 did you not use new ones when you rebuilt the engine??Yea I did, came with the oem full gasket set.Will try not to handle them with bare hands and pack them with grease then, cheersIF my crank is worn then what can be done other than having the crank ground or replacing it?I have a few cranks but really want to avoid changing it. Quote Link to post Share on other sites
enzo_e492901 Posted May 25, 2011 Share Posted May 25, 2011 Like you say if it's a groove the easy fix is to try and get the seal to sit about 1-1.5mm further out. Other than that I think you can get shaft repair sleeves but I think they change the size of the seal needed. You could get a sleeve that has the same o/d as the crank seal face and machine the crank down so that the sleeve is a tight interference fit onto it. But I would not want to do that to the flywheel end!Gavin Quote Link to post Share on other sites
andy.i Posted May 25, 2011 Share Posted May 25, 2011 you could get the crank sprayed and turned down, wouldnt cost too much Quote Link to post Share on other sites
