Guest Enzo Posted July 11, 2011 Posted July 11, 2011 wasent expecting to do another one but ive had orders from the man upstairs so im doing another group buy of 4 units!he wants to clear current stock to make way for some fresh unitsthis group buy will run till the 10th of Augustpayment can be made by bank transfereplease show your interest and also spread the word 1)2)3)4)oh and the price 375 + deliverythats a saving of 130 over the RRP the turbos come with intercooler gasketwater gasketoil gasketplease enguire with a pm if you need any other gaskets, i keep them all in stock.payment details are paypal ---> geocool69@yahoo.co.uk*please remember to add your full name, fulll address and telephone numberpm me if you would like to do a bank transfer*****its vataly imortant that you prime the turbo before operating it,******** its the only way these turbos failinstructions on how to do so is herehttp://www.ukstarletclub.com/forums/index....showtopic=12142the biggest killer of turbos is oil. oil starvation, oil contamination, incorrect oil viscosity, not being correctly primed, switching the engine off before its cooled down, boosting before the oil is at the correct temp and viscosity to fully lube the bearings, ect. its all about the oil and lubrication of the bearings Quote
Guest Enzo Posted July 13, 2011 Posted July 13, 2011 thought id should add the actual spec, and links hereGT-spec ct-9 hybrid for the turbo ep market. (3rd revision)The pic shows difference of inlet trumpet size of hybrid and standard ct9Enlarged Compressor Inlet Trumpet to a massive 55mmCompressor Wheel (Garrett GT type) 39.6mmstandard ct9 for comparrisonTurbine Wheel CT-9 StandardTurbine Housing CT-9 StandardBored out wastegate port to 28mmNew wastegate flap 32mmInternal specFully BalancedNew Journal Bearing270 degree(standard)thrust bearingOperating paramatersCan withhold 1.1bar of boost (thrust load with at least 55psi of oil pressure at 5000 RPM(engine warmed up to operating temperatures)Requirements * Uprated actuator. Do not use the standard Actuator. It is recomended to use one with a harder spring, * Uprated blow off valve. The standard recirculating blow off valve promotes compressor surge. * Relocated filter. The inlet trumpet on the turbo is too big for the standard inlet pipe requring the front mounting of the filter which will also aid the response of the turbo. * Uprated Rocker cover breather Quote
Steve GT Posted July 13, 2011 Posted July 13, 2011 ill just add here if you dont mind geoi tested a GT spec out a few months ago. Amazing little turbo. improves spool over the standard CT9 and pulls like hell in the higher revs. well worth the money id 100% reccomend buying one of these Quote
Josh@TunerLifestyle Posted July 18, 2011 Posted July 18, 2011 that looks exactly like the turbo i have, but mine says ct 12 on it :s Quote
madmax_926 Posted July 18, 2011 Posted July 18, 2011 how much is delivery and when do you require payment? thanks Quote
200bhp starlet Posted July 18, 2011 Posted July 18, 2011 bought one of these a few weeks back off enzo great bit of kit and top bloke to deal with bargain at that price too lewis Quote
mckel Posted July 19, 2011 Posted July 19, 2011 What sort of power would this be capable of? been looking for a hybrid and this is a really good price to turn down.Bryan Quote
Guest Enzo Posted July 19, 2011 Posted July 19, 2011 @ joshyboy some of them used ct12 compressor casings for a slightly biggar ar, its just when mr tong can get a hold of them he uses them@chichi any oil you usualy stick in a 4efte will do, but i usually use 10w40 for the uk climate, which might not be the right weighting for where you stay.@madmax the sooner the better mate and delivery works out at £21@mckel your looking at 190-210 dependant on boost pressure and setup Quote
mckel Posted July 20, 2011 Posted July 20, 2011 give me a shout with payment details and i'll get the money to you asap 1) mad_max9262) mckel3)4) Quote
Guest Enzo Posted July 20, 2011 Posted July 20, 2011 pm me when you do Jeroen and im sure i could work something outpm sent mckel Quote
MARC MOSS Posted July 20, 2011 Posted July 20, 2011 I've had one running 1bar for ages now it's a good investment at a bargain price Quote
doughnut ep91 Posted July 21, 2011 Posted July 21, 2011 hi enzo.really intrested in having this turbo,please let me no when you want the money,and how you want the payment.you say you have a stronger spring does that go in the accuator or should i just buy a up rated accuator?mant thanks terry(doughnut ep91) Quote
Guest Enzo Posted July 21, 2011 Posted July 21, 2011 soundo mate, as soon as possible for the funds to save on disapointment as its really first come first serve.i dont understand what your saying about the stronger spring though, you would be just best off buying an uprated hks actuater for this when i get back i will add payment details and other information in the first post Quote
doughnut ep91 Posted July 21, 2011 Posted July 21, 2011 no worries,could you let me no how much your uprated actuators are please,that was what i meant to say not for a stronger spring. Quote
Guest Enzo Posted July 22, 2011 Posted July 22, 2011 ahh ok i understand you now, i usualy dont push to sell these and would recomend you to get a hks version but i could enquire if your interested in a price ive added payment detailsgaskets the turbo comes withand priming instructions to the first post Quote
madmax_926 Posted July 22, 2011 Posted July 22, 2011 hi enzo looking to pay in full this evening is that 375 with delivery included? Quote
shorty Posted July 22, 2011 Posted July 22, 2011 these are seriously wicked turbos! I've always pushed the fact that hybrids are a brilliant upgrade for those after the 200ish mark. the tourqe is sick! fantastic price too! Quote
Guest Enzo Posted July 22, 2011 Posted July 22, 2011 oh and the price 375 + deliverythats a saving of 130 over the RRP @madmax the sooner the better mate and delivery works out at £21at madmax there ya go mate:) Quote
madmax_926 Posted July 23, 2011 Posted July 23, 2011 at madmax there ya go mate:)so in total 396 + sorry to be dumbbut how much do i need to add paypal fees? Quote
