tez Posted July 18, 2011 Posted July 18, 2011 helloive been having problems with my boost pipes popping off.I used the tercel hks actuator guide.121mm for 1 bar.which turned out to be120mm at 1.5 bar lolopps.(first gear)i didnt port my second turbo as i was in a hurry and didnt know what condition it was in!The turbo had 2mm play!ModsJam ecuFMICported manifoldblitz decatfront mounted air filterUprated leadshks actuatorso i reset the hks actuator 3mm more at 124mmit now boosts at 1.1 bar(1.0 Bar ish)could the actuator be fucked?or the turbo overboosting?This is all in first gear. will it be ok?cheersand yes im still popping the same boost pipe off! Quote
DavidAshton Posted July 18, 2011 Posted July 18, 2011 That guide is a load of shit. Each car is different, start at low boost and gradually increase the boost pressure a few turn at a time on the actuator to get to the desired level. Quote
tez Posted July 18, 2011 Author Posted July 18, 2011 im at 1.1 bar now in first gear, will it be the same throughout the gearsWill this be ok for my ct9?More worried about my engine, rather than the turbo lol Quote
ro55ifumi Posted July 18, 2011 Posted July 18, 2011 That guide is a load of shit. Each car is different, start at low boost and gradually increase the boost pressure a few turn at a time on the actuator to get to the desired level.That or fit a boost controller John Quote
TrisK Posted July 18, 2011 Posted July 18, 2011 That or fit a boost controller Johnbut still start low, as you cant go lower than the actuator Quote
tez Posted July 18, 2011 Author Posted July 18, 2011 i might buy a HDI or a GIZZMO?should i set my actuator lowerthen set my boost controller higher?or vice versa?or will a MBC be ok? Quote
Sparky Posted July 18, 2011 Posted July 18, 2011 if your hitting 1.5 in first gear good job you didnt take it any further, with the extra load in say 3rd gear you would be hitting 1.8+ I bet and you would be in a whole world of shit.You sure its all hooked up right never seen one push that amount of boost Quote
Socks Posted July 18, 2011 Posted July 18, 2011 dont buy a hdi bc dudecant rate the gizzmo enough! i would set the actuator to 0.7bar and tune with the boost controller from there! Quote
tez Posted July 18, 2011 Author Posted July 18, 2011 Ok will have a search for a ebc!regarding the actuatorwhat sort of boost should i be looking at in first gear?its hooked up correctly with vac hose from turbo to actuator!where the actuator hole is and it goes onto the wastegate connector, i had to use a bolt and 2 nuts to fix it. should be ok though!i had to pull out the actuator slighly to get it to mount onto the wastegate bolt though? Quote
Driver Posted July 18, 2011 Posted July 18, 2011 I wouldnt worry about it, mine was 1.5 daily and spiked to 1.8 under load all time haIf its done it and survived just turn it down and should be fine (Y) Quote
