Hello I`m Bastel,
I`m from germany so that is the point of my not so good english. I hope that is not the problem.
I`m 27 years old and I have a Toyota Paseo EL 54.
My car has a lot of tuning vacuum behind.
Tuning:
Suspension + wheels [/ b]
16 "Alloy Wheels OZ Alleggerita HTL summer in white with 215/40R16 tires
15 "aluminum rims from winter Aluette only now without a directional arrow and in white painted
30-0 Suspension H & R springs
Bill Stone damper
Home-made front strut brace
Self-built strut front suspension
Self-built rear strut bar
Self-Assembled Rear Stabbistange
275mm brakes on the VA
look [/ b]
Font: Crazy Car approach
Rear: Single production
Sill: Crazy Car
Rear spoiler: Fa Wecktor
Front with additional air intake
Bonnet with air outlet
Windshield washer nozzles removed
Headlights
shortened door-lock pins
16V antenna
Seats from the '94 U.S. Paseo
Suspender belts
+ motor drive [/ b]
Si E10 airbox
Sport air filter mat
3S-GE 2.0 L throttle
ACIS intake manifold rebuilt from Japan
intake ducts dilated
Cylinder head planned
Harder valve springs
265 ° camshaft
Variable fuel pressure regulator
Adjusted timing
Thermostat controlled oil cooler
Oil pan from U.S. model
manifold
200 cells Kat
Katback exhaust system with one-off production at the end of duplex
lightened flywheel
Clutches
6 speed gearbox
ECU soldered
extra tax for the gardener ACIS
Broadband lambda probe
Knock Sensor retrofit
Greddy e-Manage Ultimate engine control
Sound [/ b]
Alpine radio
slightly better midrange and high-
My poor English will be repaired by Google: D
I hope
I have no idea how much power the engine has. Next month, it goes only to the test. :D
Thanks for the nice words of welcome.
Could indeed 5E-FE engine has indeed some similarity with the 4E-FE therefore we assume the cylinder head plug and play. :D
The 6 speed gearbox would be plug and play. :D
The exhaust system would be useful to compensate for changes in a vacuum Starlet :D
  • 1 month later...
  • 1 year later...
It´s a long time agobut I´m here.
Now I´m testing to go up to the 160HP.
But I need help!
I´m search a Cylinder Head Gasket. They must of metal and so good for cooling the Cylinder Head.
They musst by 1mm or thinner
Can you help my and give my some links?
  • 2 years later...
Some Years later :
Update
900Kg
140HP
manny Carbon
c160 Gearbox
Big Break Kit (275mm break disc, 2 Piston break kaliper)
EVO7 Rearwing
ff49510326edd5b6c81c560da47ad869.jpgdac36beb4e9b23e06cfa538f3bb07d73.jpgef53924fa0c2b69fe5a8747a04c42a1f.jpg04d72779e442bbf8c8abecda7fe3a50a.jpg
Edited by Bastel
The colour is from Hyndai.
In this winter I will chanche the basic ecu. I have two favurat systems.
1 = Toyota 4E-FE Gen3 in combination with Greddy eManage Ultimate
2 = Mitsubishi Lancer EVO 8 as stand alone
I'm not sure what's better.
