GT Phayer Posted October 15, 2011 Posted October 15, 2011 Ive come up with this problem i have a ram horn manifold with screamer and the wastegate is getting in the way of the bottom hose ? has someone had this problem ? also do the waste gates get hot i would think they do as its part of the exhasust but might be wrong any ideas how to solve it ?thanks. Quote
nazzurro19 Posted October 15, 2011 Posted October 15, 2011 what kit is it uve got ? i have a similar problem where my screamer is on the bottom rad hose all i did was put a 3 ply bit of rubber over the screamer Quote
GT Phayer Posted October 15, 2011 Author Posted October 15, 2011 hybrid tdo5 waiting for the pictures to load lol Quote
Dean @RW-Developments Posted October 16, 2011 Posted October 16, 2011 that will more than likely burn through the pipe. Quote
GT Phayer Posted October 16, 2011 Author Posted October 16, 2011 any ideas of a simple fix to avoid it ? Quote
_shaun_ Posted October 16, 2011 Posted October 16, 2011 i put a bit of think rubber between the pipe scream n seemed to have solved it for me Quote
GT Phayer Posted October 16, 2011 Author Posted October 16, 2011 does the wastegate get really hot ? i was thinking to just raise the rad so i have a gap between them and hopefully shouldnt melt Quote
Dean @RW-Developments Posted October 16, 2011 Posted October 16, 2011 the anodized bit doesn't get too hot but the exhaust bit of the wastegate does Quote
GT Phayer Posted October 16, 2011 Author Posted October 16, 2011 ok thanks mate so will a 10mm gap be ok or will it still melt the rad hose ? Quote
Dean @RW-Developments Posted October 16, 2011 Posted October 16, 2011 ye should be ok maybe put a bit of heat wrap around the radiator pipe just to be sure Quote
GT Phayer Posted October 16, 2011 Author Posted October 16, 2011 what the silver stuff or like i have on my manifold ? Quote
rorenapier Posted October 16, 2011 Posted October 16, 2011 Move the bottom port of the radiator. Quote
Dean @RW-Developments Posted October 16, 2011 Posted October 16, 2011 is that a big job ?think hes on about cutting the pipe off welding a small alloy plate over it re drilling the tank and welding the pipe back on, if you wanted to go down this route i could do this for you no problem, you would be looking at £15 to do the above^^ but postage would need to be sorted there and back just drop me a pm along with the sizes for the oil return pipe we was chatting about, if not just use exhaust heat wrap and see how you go Dean Quote
rorenapier Posted October 17, 2011 Posted October 17, 2011 As above, cut the spigot off the rad, weld up the hole and re-position the spigot to where the radiator hose sits properly. Drill hole and weld back on.Ive had mine like this for 3 plus years!!I cant understand why people will bend the hose about to fit the rad, when it will sit closer to a heat scource!! Its there to cool, not get heated up.Wrapping hoses isnt fixing the problem, its mearly masking it.Do things properly or not at all Quote
MARC MOSS Posted October 17, 2011 Posted October 17, 2011 I have this problem,my screamer is 10mm away from my bottom hose too... I wrapped the pipe and used a cable tie around the rad hose and the body to just pull it away a bit more...1500 miles later I've stopped worrying about it Quote
TrisK Posted October 17, 2011 Posted October 17, 2011 i had a proper civic rad kit from jezzamy mechanic paniced about it and raised the rad using a custom top bracket. but i dont know. looks like with some lagging i would have been fine Quote
