★ The AE-202 Project ★
  • Replies 144
right been away for awhile, busy with work..
finally got some work done on car
my 6k hid in the fogs broke (cable got caught in something and it broke) so i decided to buy a 3k hids
also bought an apexi rsm, wired it but could not get speed to work
then spoke to richard and we figured it out
(this is 3rd gear, ran out of rd)
  • 2 months later...
not really noticed that im afraid..
right car is back on the road after changing quite a number of things
new cambelt
new waterpump
2 cam seals
1 crank seal
new dizzy cap
new rotor arm
new coolant temp sensor
antifreeze
did compression test on it again and it was 10.5 bar across all 4.. need to do a good few services and see if i can get the compression to come back up abit
few more pics i took after i got it back, sooo hard keeping white wheels clean.. :pale:
really need to sort out and clean up engine bay wiring toooo, also maybe getting a custom strut bar made toooo :D
sorted out the brake line so that its not rubbing on cambelt cover
guess what i found afew days ago...
its the birth look of my car :p...
they are 2 different cars (not photoshopped)
some more pics from today
just messing around with editing them, some of them are ok and some arent, i need a new camera :cry:
engine bay shots
the washers
Nardi gearknob
  • 10 months later...
here you are
cleaned the filter on my clean ace as a new one is like £34 from toyota :affraid:
thanks for the tip shehroze
after cleaning
fitted my air purifier today
and a random shot of my car
and my brakes that need to go on
really neeed to clean my car now, 2 quick pics i took..
hate the fact i have white wheels and no time because of work...
I installed the BC coilovers today. I've set the damper knobs to 0 clicks from fully soft on the fronts and 5 clicks from fully soft on the rear.
I'm VERY impressed with the ride quality of the BC's.
The ride comfort was virtually the same as stock spring/strut combo
Going around corners you could definitely notice the difference in the handling performance as it stuck to the road as if it were on rails. So much more responsive.. Im loving them so far :twisted:
They dont actually make the car look lower than before.
dont know why the damper knob is upside down but its set to soft
Attempted the st202 carrier and 275mm discs, unfortunately didnt fit
the disc sits too far back and carrier just catches the disc at the back
so fitted the twinpots to my stock 255mm discs for now
Got 2 new optional extras
My new armrest, needs a clean
563675_10152809882475495_1545344106_n.jp
My C-Pillar Map Lights
Dont want to fit these until i have a template of some sort
Anyone know what colour wire does what?
Some better pics of the arm rest
Multibox & cupholders
Clean Ace
Flare
my last pic was awhile ago, so thuoght id take afew more today
Looking well Mate
Thanks
just paid for this little beauty, hopefully have it within a week :twisted:
DDC5D89C-37A9-4D0C-9947-CFA643D2CE3C-782
953CC2FC-1555-4322-955C-4D34E439D588-782
5625117E-5B54-434D-A146-54F92EEC9B3F-782
guess what arrived today
all plugged in
Also got some TRD leads..
some comparison pics of the TRD leads vs the Ultra Power 7mm Leads
TRD lead
The Dizzy side
(Trd on left, Ultra on right)
The spark plug side
Ultra Power Leads fitted
TRD leads fitted
one of my mates got some new wheels, decided to try them on my car... now i want them lol
16" Rota GT3
Also finally fitted my 275mm discs
the 255mm discs
the 275mm discs
275mm brakes
some pics i took whilst the sun was out
Ultra Power Leads back on
got some more pics
bought a deck spacer and aluminium radiator today (no pics of the rad, will get some tomorow)
fitted
much better mid range and top end, hasnt affected low down pull (which was already great)
sad thing is that i cant fit my strut brace on there anymore :(
Fitted my aluminium radiator & fitted a 2 point strut bar too as the 3 point one doesnt fit anymore
got my ARC Magic Chamber today
ARC has developed their very own unique versions of Induction Boxes and Intake Chambers. The ARC Intake Chamber helps raise the torque at low and mid range (RPM) engine speeds and is also very effective in improving accelerating speed. The ARC Box focuses on low, mid, and high RPM engine response. When stepping on the gas, in between the cleaner and the intake manifold is unused air. ARC invented this Super Induction Box to utilize the unused air and give it better airflow and better response.
afew more pics of the ARC
got a new grille today... for tyler lol
Ae101 Hella Grille
Fitted to the car
Got some new JDM Rims, quite different to what I've had in the past.. alot of mixed opinions about these.
Need a really good clean and polish and hopefully they will be back to their former glory
Heres the specs
Wedsports RS-5
16x7JJ ET45
Front just fit, rear i put on 5mm spacers
Had a really bad week this week,
quite lucky / unlucky (whichever way you want to look at it)
Sunday morning on the way to work, tyre blew out at aroun 65-70mph
quite lucky that there was rubber still on the edge, guessing thats what gave me more control and stopped the car from spinning, glad that there was hardly anyone else on the road as the tyre flew back and bounced across all lanes on the motorway, pulled into the hard shoulder and swapped the alloy for a space saver i had in boot. funny thing is that it didnt fit and i had to use spacer behind it to space it out because it was catching on brake caliper carrier..
Got to work all right and then realised how lucky i was,
thought about it like there was the initial shock from the blow then instinct kicked in to keep car straight, got to work all right.
on my lunch break went to go get the alloy checked out and new tyre fitted, they were quite surprised that there was next to no damage to the alloy and all they had to do was to replace the old wheel weights and put a new tyre on, balanced up ok
so that was day 1 over, on the way to work the following day i hear a really bad grinding sound from the passenger wheel, got about 5 mins from work and brakes failed, quite literally foot hit the floor, pumped it and got pressure, then drove again and foot hit the floor. This had happened to me in the past and it was due to the nut on the drive shaft coming loose, so again on my lunch break i took it down to my mates scrapyard to get it checked out, i was running late and left it with him to repair the fault. He phoned me 20mins later to say " you're very very lucky" again im thinking whats gone on today, so i take another break from work and go down to his yard, car was up on ramps and wheel was on the floor with half the hub attached to it.. i couldn't believe what i was seeing :shock:, half the outer cv joint had snapped off with the nut attached and the wheel bearing had collapsed.
the wheel bearing is pressed into the hub and should NOT come away like this at all
and the driveshaft, inner CV split and outer thread snapped off
got some more pics
Got my BZ Touring grille for my car
need to paint it to the same colour as the car though
Finally sorted out my driveshaft and changed gearbox oil
Got a new manifold system
Its a jasma 051 (Etching K S) system, which I've found is also known as HKS
this what the bottom of the old system looked like, loads of welding due to it snapping twice there lol
Going to attempt to polish it soon
In comparison to the FGK system
also re-fitted the RSM and a new cd player, and a boost gauge (wanted it for the vacuum gauge) to try to save abit more fuel lol
