Azz Posted January 25, 2012 Posted January 25, 2012 I'm after buying a set of coilies for my ep91, I have a bad back so i don't want a rock hard drive!Can someone tell me the best to get, I've heard d2's are hard so ......... NO ha ! Quote
ro55ifumi Posted January 25, 2012 Posted January 25, 2012 Meisters as they are Starlet specific Quote
Jamie1st Posted January 25, 2012 Posted January 25, 2012 Meisters are the ones bud as John said. Quote
Azz Posted January 25, 2012 Author Posted January 25, 2012 Cheers fellas, looks like Il be putting a wanted add in then lol Quote
Liam_D Posted January 25, 2012 Posted January 25, 2012 I have BCs dude and to be honest they are rather hard but that could be the settings i have dialled into them!Have heard that Meisters are a lot softer though! Quote
Azz Posted January 25, 2012 Author Posted January 25, 2012 Well I'm running kyb shocks at the minute with 30mm lowering springs i know you can get 50mm springs but I don't know if they would fit my shocks, I'm torn between the meisters in or new lower springs :/ Quote
Liam_D Posted January 26, 2012 Posted January 26, 2012 Meisters will be better for adjustments etc dude. Quote
morgey Posted January 26, 2012 Posted January 26, 2012 im on bc's massive difference between soft and hard, so can be ajusted to suit your needs. only thing i can say with bc's is that adjusting them correctly (not moving the spring seat) the rears dont go particularly low, whereas im sure meisters do! Quote
ryan lang Posted January 27, 2012 Posted January 27, 2012 Meisters as they are Starlet specific when you say specific, do you mean only for starlets?also azz, meisters are amazing i had a set on mine and the difference is crazy, the hardest setting rattled my radio out. then the softest setting is liking floating through clouds deffo deffo worth the money Quote
ro55ifumi Posted January 27, 2012 Posted January 27, 2012 when you say specific, do you mean only for starlets?also azz, meisters are amazing i had a set on mine and the difference is crazy, the hardest setting rattled my radio out. then the softest setting is liking floating through clouds deffo deffo worth the moneyTaken from a post that Geo did RyanTheZeta-R Coilovers had many adjustments made in order to make thecoilovers better for everyday fast road uses. The basic remains the sameas before using high quality adjustable monotube dampers, linear ratesprings, and a modern dual perch coilovers design. Zeta-R have reviseddamping specifically made for the UK roads, longer damper stroke travelfor the bumps and dips, and 32 stage damping adjustment for fine tuningyour desired ride.John Quote
ryan lang Posted January 27, 2012 Posted January 27, 2012 ah i was confused because you had put starlet specific loli was going to say they do them for alot more than just starlets lol Quote
Taggy Posted January 27, 2012 Posted January 27, 2012 I think i am the only one on her running D2's they are HARDer than nails lol on the road, not comfortable at all, although good for track Quote
Liam_D Posted January 28, 2012 Posted January 28, 2012 Yeah ive been told D2s are silly hard! Too hard for UK roads in fact! Quote
