use a heat gun or hairdryer on the edges n then work into the middle and peel off, simple as be careful tho because the paint can crack so go slooowly
Or (next summer) leave the car out in direct sunlight for a few hours. Worked a treat for my mate. After you've done that side turn it around.
i used a hairdryer on 1 side which worked good n the other side was in sunlight so it just peeled off easily. But peel it slowly incase it rips your paint off.
I also used petrol to remove the sticky adhesive underneath the strip.
But shaun: why do you need to spray it afterwards?
i dident say that i sad just hope the pannel hasent been sprayed before as they proberly mask around the strips so when you take them of you will have a fat paint line.
Shaun is right, thats exactly why mine cant come off, because they've been masked and the panels resprayed, meanin there's about 2 coats of laquer less under the strips. Remoin them would need the panels resprayed, hence i'm gonna be different and colour code mine. :angry:
Phil.
just hope they have not sprayed the sides and mask around the strips as you will havt 2 get it sprayed
<{POST_SNAPBACK}>
exactly the problem i found on mine! its amazing how much a difference it makes to the car..... i found rubbing the glue residue left with autoglym tar remover made taking the glue easy to rub off!
it was a nightmare getting mine off, even with a hair dryier on a sunny day,
not having the right tools didnt help either!
your right ian, made a totaly difference
  • 4 weeks later...
if your sure your car hasnt been respraye then is there any chance anything else could go wrong im going to try ths i hop to f**K it works cause i dont have enuf money to get it sprayed!!! so all i do is hair dryer it"" slowly as in make sure a the outsides can pel off then work your way along an making sure its all peeled off sort of thing yeah!!
Was an absolute bastard to get mine off. The sticky shit underneath took about hour and a half each side to remove. Worth it though
it weekens the glue,
the best tule to get it all off is an electric buffer on a drill,
takes all the shit of in seconds
I used this special adhesive remover spray to take the glue off the back of my car once stickers were removed. available at b&q i believe, didnt buy it myself as my dad had some.
right boys its now official im doing it tommorow if it doesnt rain thaat is wish me and my flamethrower good luck i think we might neeed it!!! lol i fuckin hope not!!!
