Shahzad Posted March 22, 2012 Posted March 22, 2012 Have you tried turning the steering wheel? lolTyres, suspension setup etc be abit more specific Quote
Hawwy Posted March 23, 2012 Author Posted March 23, 2012 Toyo proxes, bbs wheels 15 lowered springs and shocks Quote
morgey Posted March 23, 2012 Posted March 23, 2012 WHats the problem youve got, understeer oversteer? EtcHave you had your tracking done? Checked tire pressures, bushes, arb droplinks, ball joints, trackrods all ok? Quote
Hawwy Posted March 23, 2012 Author Posted March 23, 2012 Or do gkanzas just have rubbbish handling Quote
Asad Posted March 23, 2012 Posted March 23, 2012 cant expect a 10+ year old car to handle like its on rails....throw some money towards a decent setup and im sure it will put a big smile on your face, as above get some parts brought! Quote
wssoR Posted March 23, 2012 Posted March 23, 2012 coilovers, anti roll bars, anti lift kit, struts, descent tyres etc. Your not being very specific as to how your car behaves so how can people help Quote
Hawwy Posted March 23, 2012 Author Posted March 23, 2012 Well i took a bend at about 80 and back end came out and car spund around full 360 Quote
rinseep82 Posted March 23, 2012 Posted March 23, 2012 ^^^^ is this with stock suspension or what???? Quote
Hawwy Posted March 23, 2012 Author Posted March 23, 2012 Its got uprated shocks and lowering springs Quote
Hou Posted March 23, 2012 Posted March 23, 2012 Something isn't right with it then, the starlet was the most predictable car I have ever driven. If the back came out at that you either threw it into the corner too fast, you rear tyres are poor, you let off the gas, the road was greasy or just driver fail! Quote
5T4R7ET N/A Posted March 23, 2012 Posted March 23, 2012 the back end only comes out on my starlet if i turn in hard and lift off, otherwise its more understeery and very predictable.you could of hit a bump? or braked hard before turning in ( unbalancing car) Quote
Hou Posted March 23, 2012 Posted March 23, 2012 the back end only comes out on my starlet if i turn in hard and lift off, otherwise its more understeery and very predictable.you could of hit a bump? or braked hard before turning in ( unbalancing car)^^^^^^^THIS!Everyone knows starlets understeer, then you let of slightly, back steps, and power out of it!At 80 you were lucky not to have totalled it Quote
cazzac2222 Posted March 23, 2012 Posted March 23, 2012 Good handling cars with the correct handling mods imo ;) All been stated above Quote
WallaceGlanza Posted March 23, 2012 Posted March 23, 2012 If you want helpful answers stop being so vague..... As above, these cars don't oversteer unless something is amiss - most likely the rear tires. Mine is oversteering like a mofo just now as I've swapped the winter tires onto rear only (the understeer and lack of traction was getting boring) - very interesting handling in the wet!The main thing to improve the handling is good tires after that a rear anti roll bar makes a huge difference with them. Quote
pick1 Posted March 25, 2012 Posted March 25, 2012 I agree a better set up is required if u are attempting corners at 80mph I'm running D2 racing coilovers 40mm lowered and very stiff , front anti roll bar and strut brace and rear anti roll bar and strut 15inch rims wrapped In toyo proxie T1R's Quote
Liam_D Posted March 25, 2012 Posted March 25, 2012 Im running a pretty good set-up and even i wouldnt attempt corners at 80mph, Quote
200bhp starlet Posted March 25, 2012 Posted March 25, 2012 80 is quick for most cars to be going round corners as above invest in a good set uplewis Quote
festival500 Posted May 21, 2012 Posted May 21, 2012 most probably your tires like most people are saying bud, I've got crappy rubber on the back atm and it can be a right handful. Quote
Flaminsam Posted May 22, 2012 Posted May 22, 2012 Also is the rear of your glanza stripped out? If so your corner weights will be well out. Quote
