russ78 Posted March 30, 2012 Share Posted March 30, 2012 if i fit a catch can do i need a breather filter anymore ? or can get rid of it Quote Link to post Share on other sites
WallaceGlanza Posted March 30, 2012 Share Posted March 30, 2012 Depends how you're setting up the catch can - have a search on here for the best setup, there's a lot of topics on it! Quote Link to post Share on other sites
Dean @RW-Developments Posted March 30, 2012 Share Posted March 30, 2012 its usually good to have a breather on top of the catch can Quote Link to post Share on other sites
Hawwy Posted March 30, 2012 Share Posted March 30, 2012 My catch can goes one tube to rocker. The other points to the ground outside through engine bay, is that right? Quote Link to post Share on other sites
russ78 Posted March 30, 2012 Author Share Posted March 30, 2012 Well my catch can has no breather on top so Im guessing it goes top right on rocker cover to one port on the can then from the other port on the can to the manifold but do i need to gut my pcv valve ? Quote Link to post Share on other sites
russ78 Posted March 30, 2012 Author Share Posted March 30, 2012 I can just leave my breather filter on the far left rocker valve Quote Link to post Share on other sites
russ78 Posted March 30, 2012 Author Share Posted March 30, 2012 My catch can goes one tube to rocker. The other points to the ground outside through engine bay, is that right?as far as Im aware this is right also if you wanna set it up this way but i think it will work much better the way i wanna do it Quote Link to post Share on other sites
WallaceGlanza Posted March 31, 2012 Share Posted March 31, 2012 Well my catch can has no breather on top so Im guessing it goes top right on rocker cover to one port on the can then from the other port on the can to the manifold but do i need to gut my pcv valve ?You will need to gut the pcv yes and move it so it is inline before the catch can.The ideal setup imo is using two sealed catch cans, one as above in between inlet mani and the breather with the pcv (with pcv moved to inbetween catch can and inlet mani). The other can goes between the other breather and the turbo inlet with no valves as this one is meant to be permanantly breathing/open as in the standard setup.This setup can be done with one three port catch can and a system of valves:http://i819.photobuc...UKSC/catch2.png Credit again to enzo_e492901I say this setup is the best as it is legal - doesn't put any oil on the ground and breathes properly as the standard set up does, it also pulls a vacuum on idle to keep the system clean, if the hose just goes under the car it may pull vapours out at speed but not when sat still. Quote Link to post Share on other sites
Russleh Posted March 31, 2012 Share Posted March 31, 2012 ^^^^ someone stamp that shit so it comes up whenever someone mentions a catch can lol Quote Link to post Share on other sites
russ78 Posted March 31, 2012 Author Share Posted March 31, 2012 why is something so simple so bloody confusing lol Quote Link to post Share on other sites
Johnboy GT Posted April 1, 2012 Share Posted April 1, 2012 Haha i thought oh Fuck not again when i saw this topic come up!! Quote Link to post Share on other sites
russ78 Posted April 1, 2012 Author Share Posted April 1, 2012 (edited) all engine bay pics i can find everyones got there catch cans going everywhere !!there all different lol think ill stick to the diagram provided by enzo_e492901but reposted by Wallaceglanza as that seems the most accurate science haha Edited April 1, 2012 by russ78 Quote Link to post Share on other sites
tommyep82 Posted January 4, 2015 Share Posted January 4, 2015 Can't you gut pvc valve and block of pipe to inlet. And just plumb the two breathers on rocker covers to catch can with a breather on it? Not asking is it legal but isn't engine breathing property like this? Quote Link to post Share on other sites
Sanjeewaglanza Posted March 5, 2016 Share Posted March 5, 2016 Fellas which is quick spool vf32 vs td04..?? Quote Link to post Share on other sites
patman Posted March 5, 2016 Share Posted March 5, 2016 Fellas which is quick spool vf32 vs td04..??Wrong section mate Quote Link to post Share on other sites
