kingo228 Posted April 9, 2012 Posted April 9, 2012 is this possible ? if so what rods can this be done with ?thanks Quote
_shaun_ Posted April 9, 2012 Posted April 9, 2012 can be done with any forged 4e rods but the question would mainly be why do u just want forged rods Quote
PaulStarletSR Posted April 10, 2012 Posted April 10, 2012 u cud do it....if u wana blow half the engine thru your bonnet.if your gona forge, dont b tight and go the full hog with pistons 2. id-workz is a supplier of such parts ;-) Quote
Asad Posted April 10, 2012 Posted April 10, 2012 id change the piston and keep the stock rods, stock rev limit and a good amount of boost......this is what they used to do back in the days i was toldwhy not if your on a budget? you dont have to follow what everyone else does, build in accordance with your budget...decent rods cost a fair bit Quote
Idrees Posted April 10, 2012 Posted April 10, 2012 The ring lands are more like to fail before the rods! Quote
Socks Posted April 10, 2012 Posted April 10, 2012 Was gonna say ringland/pistons are more likely to fail before the rods! Quote
wickedep Posted April 10, 2012 Posted April 10, 2012 The ring lands are more like to fail before the rods!spot on..if you must change something..then change the pistons. if its for something like a td04 upgrade then stock internals will still hack it although the common trend is to fully forge for the slightest increase in power Quote
B11G KY Posted April 10, 2012 Posted April 10, 2012 It will be fine as long as you paint your rocker with heat paint! Quote
kingo228 Posted April 10, 2012 Author Posted April 10, 2012 Right thanks guys , mixed opinions. just dont want to be rebuilding my engine again when its dropped another rod lol. im only aiming for 200bhp ish would you recommend going forged or just running stock internals and making sure its running good while making that power? was thinking about shot peening but the pins are pressed in and probs damaged them while pressing them out?thanksoh yeh , i have a tight budget still a apprentice so on shitty wage haha Quote
Idrees Posted April 10, 2012 Posted April 10, 2012 Stock internals are well capable of 200 bhp as long as the fuelling is set correctly. Quote
shorty Posted April 10, 2012 Posted April 10, 2012 As above!! Wouldnt waste money that you dont realy have on forging for 200hp mate. just a healthy oem engine will be fine at 200hp all day long tbh. Quote
B11G KY Posted April 10, 2012 Posted April 10, 2012 200bhp is easily capable on stock internals as long as your fueling is on point! i ran a td04 on a bar for a year on fpr and fcd with no issues just regularly serviced It makes no sense pulling the block appart just to put some stronger rods in if your gonna do it do it properly, take your time and save a lil each month and forge next summer... if your wages dont allow you to do that then dont forge forged engines are expensive especially when they brake Quote
neilsmith Posted April 11, 2012 Posted April 11, 2012 Stock internals will be fine mate for 200bhp as long as you look after the engine and get a good map to set up the fueling properly, i currently running 230bhp through the standard internals and all is well! Quote
