Whats everyones view on this, would it be best to buy a civic triple core rad, or just stick with the standard rad?? Whats best for allowing better engine cooling etc!
Mike.
If you look at the size of a civic rad compared to the standard rad its alot smaller which means its catching a smaller area of air to cool down the coolant so a standard rad would allow more cooling, having said that the standard rad is made out of copper and steel where as the civic alloy rads are made out of alloy obviously lol.
Alloy disperses heat more efficently than copper and steel but then again the standard rad is still a bigger rad.
Would be good to see test results on this!
if you got for a civic rad make sure it is 40mm thick, or it over heat...
tbh i have run both, and the civic rad holds nearly as much coolant as standard rad...
and i tracked mine and it didnt overheat..
Made no difference at all on my temp gauge when I fitted a civic rad, people switch to civic rad for the extra clearance when running bigger turbo kits.
I also fitted my standard rad back as I didn't like the bodged fitment of the Civic rad.
Im going to be using a full size alloy rad mate, Mike said that the half size ones wouldnt cool it enough and the full size one fits on even though im using a bigger turbo kit
use a full size if you can, whack two fans on it too....if not put a civic one in alot of people use them with little complaint
I'm going for a civic style rad and from what I've been told although the standard rad at the moment is bigger the ally civic rad has 30% more cooling efficiency over stock cuz of the material they are made from , I know TD do two types of civic rads one dual core and one triple core I believe have a butchers there they might be able to give better percentages and pros and cons etc
Best of both worlds :)
John
ah but you loose out in the weight world ;)
because although alloy is light surely half the alloy is even lighter
Edited by TrisK
John
Bet tht wasnt cheap!
Thanks for the comments everyone, its not that i need to change or anything but just wanted to knw peoples opinions!!
Mike.
got a full size alloy rad for sale ;)
You got any piks dude??
Mike.
Ebay £56 :) Brand New
Ive got a Civic rad for sale if you want?
John
Cheers mate, but think im gonn keep using the standard one for now!:D
