jellybaby Posted May 15, 2017 Author Posted May 15, 2017 So I got a phone call today fromThe mapper giving me bad news my clutch pedal decided to give up the ghost during the map don't no what's caused it yet poss slave but was new or it is my clutch master cylinder so that's one thing Anouther is that they noticed a fair amount of tapping on my head which is making listing for deternation hard. Think it is valve shims anouther set back I so far spent 2700 at the place for various things I wanted to be done including the partial map. So now I got to bring the car home find out why the pedal gone hopefully it fluid related and not clutch but mapper said it just lost Pedel and decide what to do with the shims I might go Toyota as I have a trade account.It a pain and now having to take a 700 quid pay cut I am now haven't got a clue what to do Quote
jayc-glanza17 Posted May 15, 2017 Posted May 15, 2017 Mine taps like hell.Yet been mapped no problem. Unless yours is seriously bad?Need to investigate the pedal msn, maybe its leaking slightly.. Quote
jellybaby Posted May 15, 2017 Author Posted May 15, 2017 Mine taps like hell.Yet been mapped no problem. Unless yours is seriously bad?Need to investigate the pedal msn, maybe its leaking slightly..It seems bad by what the mapper said through the det cans.Yer was running fine then just lost the pedal I just hope it not internal fault but got to get car bk to colchester now from the place then work out what's gone wrong Quote
jayc-glanza17 Posted May 15, 2017 Posted May 15, 2017 Not known many slave cylinders to fail tbh.Worth a look. Quote
jellybaby Posted May 16, 2017 Author Posted May 16, 2017 Not known many slave cylinders to fail tbh.Worth a look.Exactly clutch is brand new tho and bearing unless it come off the shaft. Prob the master cylinder gone tits up not to much of a expensive fix Quote
jayc-glanza17 Posted May 16, 2017 Posted May 16, 2017 Be rare if the mc failed.. but there is a first as they say.When you getting it back? Quote
jellybaby Posted May 16, 2017 Author Posted May 16, 2017 (edited) Be rare if the mc failed.. but there is a first as they say.When you getting it back?Yer looksLike it was a pipe has popped fromPhone call I got and they checking to valve clearances for me then I will order the shims and fit them my self. IGot to decide if I calling it aDay ATM and bring it home and save some money to finish the map as current bill is 2700 but they have done a lot of work on the car in otherAreas most of it is labour tbh but that what u get by a good tuning company a high labour rate lol Edited May 16, 2017 by jellybaby Quote
jayc-glanza17 Posted May 16, 2017 Posted May 16, 2017 Get pipe back on..Give it some boost and a map.Need to see how it reacts to boost before re shimming.. Quote
Ollieh17 Posted May 16, 2017 Posted May 16, 2017 If the shims are noisy I would definitely sort them before any mapping. Probably the same as some motorbikes Quote
jellybaby Posted May 16, 2017 Author Posted May 16, 2017 Get pipe back on..Give it some boost and a map.Need to see how it reacts to boost before re shimming..The mapper recommend that they b checked due to it hard to hear the det prop through the det cans and it was bloody loud tapping fromThe head. It better to get them sorted then carry on mapping to be on safe side at end of day it what a extra 59-100 quid if I need a few shims from Toyota Quote
jayc-glanza17 Posted May 17, 2017 Posted May 17, 2017 Didnt you check them though?Mines really quite tappy nothing worth breaking over.What about the clutch issue and further clues? Quote
jellybaby Posted May 17, 2017 Author Posted May 17, 2017 Didnt you check them though?Mines really quite tappy nothing worth breaking over.What about the clutch issue and further clues?No they being checked ATM down atThe mappers to see how many are out. They just want to give me the best map possible Looks like it is just a lose connection on my braided clutch line Quote
jayc-glanza17 Posted May 17, 2017 Posted May 17, 2017 Thats a result.Are they doing a health check before map?Like a compression test.. Quote
jellybaby Posted May 17, 2017 Author Posted May 17, 2017 Thats a result.Are they doing a health check before map?Like a compression test..all that has been done before the maping started all came bk spot on just the shims I need to do now Quote
jellybaby Posted May 18, 2017 Author Posted May 18, 2017 SoUpdate from the checks the clearances are fine how ever my cam followers are wrong for the type of cams I have fitted which is causing the lobe of the cam catching on theFollowers and trying to push the shims out.!So the cams in there are now ruined so need to sorce a new set of cams or a good second handSet. My question is what power can the stock cams take ? Quote
turbo-fever Posted May 18, 2017 Posted May 18, 2017 I was running close to 350 with no problems Quote
jellybaby Posted May 18, 2017 Author Posted May 18, 2017 I was running close to 350 with no problemsThat's perfect feller just what I needed to hear Quote
jayc-glanza17 Posted May 19, 2017 Posted May 19, 2017 Stock cams are not the restriction.So stock cams r fine mate..I run stock cams and plenty others do in the 300bhp bracket.. Quote
jellybaby Posted May 19, 2017 Author Posted May 19, 2017 Stock cams are not the restriction.So stock cams r fine mate..I run stock cams and plenty others do in the 300bhp bracket..Perfect I managedTo get a set local to me so b getting themAt the weekend then got to get car back to mine fromLakeside then fit the new cams and seals etc More bloody expensive. Don't help having 3k tuning bill lol but should b able to sort that Quote
jayc-glanza17 Posted May 21, 2017 Posted May 21, 2017 3k sounds steep. What work been charged for 3 grand..Got mine sorted this weekend..Turned out inlet flange warped.so back to stock and car is fine Quote
jellybaby Posted May 21, 2017 Author Posted May 21, 2017 (edited) 3k sounds steep. What work been charged for 3 grand..Got mine sorted this weekend..Turned out inlet flange warped.so back to stock and car is fineAh IHad someSpacers made for my front arb My rear arb and para fittedCustom air intake pipe made for turboCatch can supplied and fitted Aem wideband supplied and fitted Geo set up. Throttle body stripped down and unblocked some wiring had to be sorted out to. About 2 hours of mapping to set fueling etc. There a lot they did which has made the car better. AtillGot to have it mapped once I done to cam issues IAlsoHave to do some routing of some pipe work away from manifold as they will melt through eventually There workshop labour rate is 90 a hour there Mapping is 135 its mainly labour IAm very tempted to break just to pay off myDebts and just call it a day I 30 thisYear and want a house I probSunk 20 k plus in this car and it still not doneAfter 3 years Edited May 21, 2017 by jellybaby Quote
Broony Posted May 23, 2017 Posted May 23, 2017 holy fuck, you are knee deep now don't stop or you might as well just of thrown money away Quote
jellybaby Posted May 23, 2017 Author Posted May 23, 2017 holy fuck, you are knee deep now don't stop or you might as well just of thrown money awayYer tellMeAbout it got some used cams arriving 2 moz then go pay the bill and get the car transported home hopefully sat and then get to workChanging the cams over and belt also might have to sorce cam followers depends onIf they damaged Quote
jellybaby Posted March 13, 2018 Author Posted March 13, 2018 Well well I not posted for donkeys what a hell of a start of a year I had which is leading me this way in possible selling up.  Since the new year I been battling a very serious mental illness which has cost me financially and also physically  i also have split split from my partner of 5 years and have a little one of 3 years old I have not touched the car since it come bk from the tuners with the issues of me having to sorce stock cams and also new shims which I have now got. How ever I at the stage where I not got time to work on her to get it ready for the dyno again. I also have a massive list of snagging to get through on it as well as decide what to do to reduce engine by temps.  So as it stands the car including buying it in 2007 is 25k todays market I get aprox maybe 8-9 if fully working. Stripping it I prob make little bit more but hassle of waiting for people to want bits.  I really don’t no what to do I was going to poss crowdfund and compete in a time attack series but that’s a long shot. Quote
