Matts Posted June 27, 2012 Posted June 27, 2012 Ok so this is not a great way to put it but im just wandering whats the common mpg on a standard 4EFE ? so far ive done no engine mods but it seems to be drinking fuel? it was on half and after a 30 mile trip it was on empty? i cant seem to understand it. Quote
morgey Posted June 27, 2012 Posted June 27, 2012 That does seem exceptionally bad, id get more like 50-70 from the bottom half of mine and thats a 1.6 Quote
daniel_g Posted June 27, 2012 Posted June 27, 2012 That aint good mate, just an idea, maybe swap the ecu for another ep91 4efe one, they are like 30 odd quid. Quote
jimmymac101 Posted June 27, 2012 Posted June 27, 2012 i got 250 - 260miles on a full tank! you deffo have a proplem there Quote
rob_bower Posted June 27, 2012 Posted June 27, 2012 Try changing the lamda sensor my mpg drastically improved when I changed mine. Quote
turbo Grant Posted June 27, 2012 Posted June 27, 2012 Ecu water temp sensor could be at fault or o2 sensor. I'd try a new temp sensor first Quote
Amjad Posted June 27, 2012 Posted June 27, 2012 Also check the tyre pressures and the sensor in the inlet pipe is screwed in, does it need an oil change? Quote
Matts Posted June 28, 2012 Author Posted June 28, 2012 ok guys thanks for all your help, ill start checking things today tyre pressure is fine amjad there all the same thanks and as for oil im not sure what its running at the moment i dont think its high quality stuff but ive got some genuine toyota oil and filter on order. Quote
Russleh Posted June 28, 2012 Posted June 28, 2012 i reset my miles everytime i fill up and shoot for as far over 300 as possible so 300 or close is what u should get. Russell Quote
andi Posted July 5, 2012 Posted July 5, 2012 when i had the car matt, on nice steady runs i used to get 285-325 per tank, driving round town it went down to 250. First half of tank used to get upto 200 then second half of tank went down realy quick. as russleh said reset the milage next time u fill her up. The oil in it is just wilkos homebrand 10w40w i think.hope this helps Quote
Matts Posted July 5, 2012 Author Posted July 5, 2012 when i had the car matt, on nice steady runs i used to get 285-325 per tank, driving round town it went down to 250. First half of tank used to get upto 200 then second half of tank went down realy quick. as russleh said reset the milage next time u fill her up. The oil in it is just wilkos homebrand 10w40w i think.hope this helpshey andi thanks for the information i will reset the mileage next time and keep track so i can check it against what you got yeah i gave her a full service the other day genuine oil and filter, i also have a genuine panel filter and genuine plugs to but im unsure weather to change the iridiums you put in as i prefer them and i have a k&n panel filter on order so that will be going on. Quote
DaveyDemolition Posted July 6, 2012 Posted July 6, 2012 My cars always been shit on petrol, filled up the tank the other day and went too oak wood about 90 miles away for me, there and back and I had too put another £10a in on the way home somewhere. £15 gets me about 35ish miles :/ sometimes 45ish just seems like im putting petrol in it all the time. Gave it an oil change yesterday though and I think it's a little better. What does everyone's car idle at? I think mines too high, it's about 1,200-300 sounds too high anyway Quote
Amjad Posted July 6, 2012 Posted July 6, 2012 Mine idles at 900, you're definitely using way too much! I can get 100miles to each of the top quarters. Check your whole ignition system over, earths and vacuum hoses Quote
DaveyDemolition Posted July 6, 2012 Posted July 6, 2012 It's been like it since I bought it, before I started messing with it I'll have a good check over tomorrow though ;) just recently changed the distributor cap and rotor arm because there was no electrode in my old dizzy cap and it was misfiring Sorry if I hijacked your thread by the way :/ I'll shutup now ;) Quote
andi Posted July 6, 2012 Posted July 6, 2012 i would leave them plugs in matt, ment to be good and only done a few thousand miles. Quote
Matts Posted July 6, 2012 Author Posted July 6, 2012 i would leave them plugs in matt, ment to be good and only done a few thousand miles.exactly what i was thinking mate iridiums are good! i also saw the receipt that you left me for them. Quote
