russ78 Posted August 29, 2012 Posted August 29, 2012 (edited) Ok so bought my 1AO 96 Glanza V end of 2011 Completely stock Except for Cusco Coilovers and a Greddy Turbo Timer and started modding straight away managed to run the engine lean thanks to a FCD at 1.2bar and dropped a rod. Autobahn Decat Heat WrappedSPS Stainless Free Flowing ManifoldRising Rate Fuel Pressure RegulatorRocker BreatherHi/Low Solenoid BypassHKS Fuel Cut DefenderHKS Adjustable ActuatorStarlet Gt Turbo RadAir-con RemovedRX7 S5 (13B) Top Mounted IntercoolerTRD Oil Filler CapTRD Radiator CapGreddy Turbo TimerBaileys DV26 Dump Valve8.5mm Red Magnacor Competition LeadsToyosports Catch CanSickspeed Reservoir SocksNGK Iridium Plugs Heat Range 7Tuning Developments 255LPH Fuel PumpApexi Boost GaugeTRD DecalTRD Gear Knob15' PIAA Super Rozza AlloysCusco Adjustable Coilovers Edited August 29, 2013 by russ78 Quote
russ78 Posted August 31, 2012 Author Posted August 31, 2012 (edited) Postman bought me a new turbo setup this week http://www.ukstarletclub.com/forums/public/style_emoticons/#EMO_DIR#/biggrin.pngZisco Heatwrapped Mild Steel DecatCustom Tubular Mild Steel ManifoldTurbo Dynamics CT9 Hybrid Edited August 27, 2013 by russ78 Quote
whitestar Posted September 12, 2012 Posted September 12, 2012 What did you like your autobahn decat and manifold? Did they crack? Thinking of buying both new, but can't decide which ones I should choose. Quote
russ78 Posted September 12, 2012 Author Posted September 12, 2012 had to have the decat welded as it cracked at the flange but was ok after that u can buy my old setup if u like http://www.ukstarletclub.com/forums/index.php?showtopic=56659&hl= Quote
Hawwy Posted September 12, 2012 Posted September 12, 2012 Postman bought me a new turbo setup this week Zisco Heatwrapped Mild Steel DecatCustom Tubular Mild Steel ManifoldTurbo Dynamics CT9 Hybridstill more to follow !Hows my old setup treating you Quote
russ78 Posted September 12, 2012 Author Posted September 12, 2012 Not bad at all its a bit of a tight squeeze for my rad now think im gonna treat myself to a slimline civic radiator soon as that mani is a monster twice the size of my old one lol What are you running now ? didn't u just sell your td04 setup as well Quote
whitestar Posted September 13, 2012 Posted September 13, 2012 had to have the decat welded as it cracked at the flange but was ok after that u can buy my old setup if u like http://www.ukstarletclub.com/forums/index.php?showtopic=56659&hl=Haha, it certainly would be cheap, but I'm thinking of getting a mani from zisco...and propably a japspeed decat. We'll see. Quote
russ78 Posted December 11, 2012 Author Posted December 11, 2012 (edited) http://www.ukstarletowners.com/public/style_emoticons/#EMO_DIR#/dirol.gif So much has been done since last update thought id just add a list of all mods as some have been improved and some are just new Relocated Air FilterApexi Cone FilterTurbo Dynamics CT9 HybridZisco Mild Steel Decat Heat WrappedCustom Made Mild Steel ManifoldMalpassi Adjustable Fuel Pressure RegulatorRocker BreatherHi/Low Solenoid BypassHKS Fuel Cut DefenderHKS Adjustable ActuatorBlitz Nur Spec R Stainless Exhaust SystemStarlet Gt Turbo RadAutobahn88 Front Mounted Intercooler inc HDI Short Route HotpipeTRD Oil Filler CapTRD Radiator CapSard Fuel Rail AdapterGreddy Turbo Timer8.5mm Red Magnacor Competition LeadsToyosports Catch CanSickspeed Reservoir SocksMagnetic Sump PlugNGK Iridium Plugs Heat Range 7Tuning Developments 255LPH Fuel PumpEP91 Gear Linkage Bearing KitHKS Super Sequential III Blow-off ValveHKS Grounding Cable Wire KitHDI Electronic Boost ControllerDepo Electronic Boost GaugeDepo Electronic Water Temperature GaugeTwo Gauge Pillar PodCustom Made Short ShifterTRD DecalTRD Gear Knob96 Spec Oem Front SplitterJam Racing EyelidsJD tuning Toyota blanking plate OEM 3 Point Rear Strut Bar Edited August 27, 2013 by russ78 Quote
russ78 Posted December 11, 2012 Author Posted December 11, 2012 (edited) just need a clutch and lsd and im in the market for a P&P ECU and im done, Ive had my glanza for just over a year from standard so pretty pleased with the result. Exterior mods well I have a rear lip to go on and im after a Varis Front Bumper and duck spoiler and powdercoat the alloys either black with a silver lip or all white Edited August 27, 2013 by russ78 Quote
Beastmode panda Posted December 12, 2012 Posted December 12, 2012 YES, ohh my god!! you've got a parking pole. Never even knoew starlets had parking poles on them! Quote
russ78 Posted December 12, 2012 Author Posted December 12, 2012 haha yeah don't work but I got one Quote
micky boy Posted December 12, 2012 Posted December 12, 2012 Very good progress considering you have only owned it for a year! keep it up matey Quote
russ78 Posted December 24, 2012 Author Posted December 24, 2012 UPDATE***** sadly I dropped a rod this week but on the flipside I have now moved my forged build from next year to now so watch this space for a forged update !!!!! Im unsure on what turbo setup to use as im looking around 1.4bar when completed I kinda like the idea of doing something different maybe a ct9/ct12 hybrid as one has fallen into my lap, it uses the ct12 housing for more flow Quote
Whitecurrant Posted December 24, 2012 Posted December 24, 2012 ive got 4e bottom end bearings, 4e scat rods for sale as going 5e now russel if u want them. Or you getting td engine? Quote
russ78 Posted December 24, 2012 Author Posted December 24, 2012 sounds good if its with the crank to pm me a price Quote
micky boy Posted December 24, 2012 Posted December 24, 2012 Pics of the ct12 Plans sound good mate Quote
Hawwy Posted December 24, 2012 Posted December 24, 2012 I know of a freshly forged stage 2 td enginf that been run in by td and prob done 10 miles after Quote
Hawwy Posted December 24, 2012 Posted December 24, 2012 Think u already seen it on tgtt they dropped price down to 1500 Quote
russ78 Posted December 24, 2012 Author Posted December 24, 2012 Yeah dude its kinda sold but reserved for me if it falls through Quote
russ78 Posted December 24, 2012 Author Posted December 24, 2012 Not sure if your old hybrid is gonna be much use to me now as i wanna run 1.4/1.6 bar shame its an awesome hybrid Quote
Hawwy Posted December 24, 2012 Posted December 24, 2012 Yeah dud that engine for sale ive seen the car wanted some bits seen it running its mint i could have got it for u if u could persuade guy Quote
russ78 Posted December 24, 2012 Author Posted December 24, 2012 He's got my number he's gonna let me know Quote
Got.boost Posted December 25, 2012 Posted December 25, 2012 As your only from Basildon I have never seen you out lol I'm up bas quite a or lakeside lol nice looking car tho will be good to see what a forged 4e with a ct9/ct12 hybrid goes like when it's done good luck with the build Quote
russ78 Posted December 25, 2012 Author Posted December 25, 2012 Dunno how I've never seen u either i had organised a meet just after Christmas but had to drop out because of engine Quote
Got.boost Posted December 25, 2012 Posted December 25, 2012 Ya I was going to go if its still on but be in my foucs as v still off the road lol Quote
