hi guys, having a bit of a problem with the car, sometimes, when i pull up to roundabouts the revs drop real low, and the oil light flickers, steering gets really heavy and the lights go dim
ive tried changing the icv to no avail. any ideas as to what it could be?
ryan
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
yeah its like it wants to cut out, ive put a newer alternator and battery on, and its still doing it :/
ill have to check the wiring between
yeah that ones fine, i was thinking more on the back like the n/a's :/
checked the others too :/ ill take them off and clean them up. ive still got the old home made earthing kit from my last starlet so ill bang that on too while im at it :)
oh and by the way guys, it doesnt always do this, and it sometimes idles at like 1300rpm when warm, it differs all the time (its not an air leak)
checked all the earths, made a few new connectors and my own earthing kit up
still doing it :/
spoke to the legend that is chris (nastyrash) and he said hes had this problem with most of the GT's and glanza's hes worked on and it could be the coolant temperature sensor, so gunna see if i can get hold on one asap
ryan
Oil pressure switch/lead going to it?
The only bit i dont realy get is the revs going realy low one min then high the next!!!
Edited by micky boy
