akaye4000 Posted January 10, 2014 Posted January 10, 2014 Who mapped it? Bet your glad to drive it Quote
Neil69 Posted January 11, 2014 Author Posted January 11, 2014 Got it mapped at power engineering in uxbridge adam. Bored of waiting for the original person to arrange it to be done. Bloke called zak up there did it. Was impressed with him and his openness about mapping in general Quote
Socks Posted January 11, 2014 Posted January 11, 2014 Awesome Stuff! Make sure you get your result submitted to the leaderboard! Quote
akaye4000 Posted January 13, 2014 Posted January 13, 2014 (edited) Got it mapped at power engineering in uxbridge adam. Bored of waiting for the original person to arrange it to be done. Bloke called zak up there did it. Was impressed with him and his openness about mapping in generalAh nice you weren't waiting for mikey were you? Mine is getting re done atm as wasn't happy with it at all if its still shocking then ill go else where. Edited January 13, 2014 by akaye4000 Quote
Neil69 Posted January 13, 2014 Author Posted January 13, 2014 No I was waiting for Andy for 3 months. Really annoying as did a deal with him and I had already done my bit of the deal. Win some lose some I suppose.Why were you not happy with yours?? Quote
akaye4000 Posted January 14, 2014 Posted January 14, 2014 Drove like a bag of crap and wouldn't start below 4deg so its back there for probably another 2 weeks after being there for 5/6 weeks before:( if its still crap going to cut my loses and go else where Quote
nibsey Posted January 21, 2014 Posted January 21, 2014 (edited) Awsome project! Love the wheels,think i should start on my EP70! Edited January 21, 2014 by nibsey Quote
Neil69 Posted January 22, 2014 Author Posted January 22, 2014 Awsome project! Love the wheels,think i should start on my EP70! Thanks. They do set it off Quote
Socks Posted February 3, 2014 Posted February 3, 2014 Result Validated on Leaderboard! Thank You! Quote
Stu Posted February 3, 2014 Posted February 3, 2014 (edited) Nice work!!! With the rear dics, did you measure the inner bearing diameters comparing the EP70 with EP82? Years ago I found there was a difference in size that needed a tapper shim to correct - luckily I found a Corsa GP Turbo which has right size and bolted straight on. Just interested if you had the same issue or if yours was ok. Edited February 3, 2014 by Stu Quote
Neil69 Posted February 5, 2014 Author Posted February 5, 2014 I did measure and all matched up. Was a straight forward swap over Quote
mech5107 Posted February 6, 2014 Posted February 6, 2014 I had the same issue with rear disks. I did made the adaptor. 25mm inner to 27 outter diameter. What is the corsa gp you mention?Also Neil, what disks you have used? Quote
Neil69 Posted February 6, 2014 Author Posted February 6, 2014 Std disks on the rear from a mk1 ep82.You have me worried now. Still got the 82 axle so am going to strip the disc off and remeasure it.Fronts are ebc drilled grooved with yellow stuff pads again with ep82 calipers. Quote
mech5107 Posted February 7, 2014 Posted February 7, 2014 You used the ep82 axle or the stock ep70 axle? Quote
Neil69 Posted February 8, 2014 Author Posted February 8, 2014 Ep70 axle. Ep82 has different length arms . Quote
mech5107 Posted February 8, 2014 Posted February 8, 2014 Then you need to check your inner bearing fitment. Quote
Stu Posted February 8, 2014 Posted February 8, 2014 I could be wrong but the one I measure had a different diameter. Quote
mas12555 Posted January 8, 2017 Posted January 8, 2017 Where did you get the fuel pump kit? http://www.tanksinc.com/index.cfm/page/ptype=product/product_id=84/mode=prod/prd84.htm Quote
