ali_legend Posted November 14, 2012 Posted November 14, 2012 As above please after the 3 standard engine mounts please. Thanks
ryan lang Posted November 14, 2012 Posted November 14, 2012 i may have some kicking about. ill have to have a rummage dude
ali_legend Posted November 14, 2012 Author Posted November 14, 2012 i may have some kicking about. ill have to have a rummage dudeIf you could please need them ASAP. Drop us a text brother!
ryan lang Posted November 14, 2012 Posted November 14, 2012 okay dude, im at the dads tomorrow so i can check then
ali_legend Posted November 14, 2012 Author Posted November 14, 2012 3 mounts? Are they Shot then?Nah mate the ha MOT yesterday and the guy said the rear engine mount has detiriated. Plus I think the other two are poly mounts and vibrate like a mofo on idle so I'll just change them all to standard.
steve-gers Posted November 14, 2012 Posted November 14, 2012 What condition are front 2 poly ones? I may swap 2 front TRD ones for them?
ali_legend Posted November 14, 2012 Author Posted November 14, 2012 What condition are front 2 poly ones? I may swap 2 front TRD ones for them?I'll have a look for you later matey and let you know
Amjad Posted November 14, 2012 Posted November 14, 2012 Wouldn't changing two front TRD and keeping rear stock have the same effect as keeping two polys? Ie not good?
ali_legend Posted November 14, 2012 Author Posted November 14, 2012 Wouldn't changing two front TRD and keeping rear stock have the same effect as keeping two polys? Ie not good?I'd get a rear TRd mount are the TRd mounts as vibrating as polys?
Amjad Posted November 14, 2012 Posted November 14, 2012 No, they're a nice improvement over stock from what I've read. But where will you find a rear one seperately? It's the rear that needs doing anyway lol
ali_legend Posted November 14, 2012 Author Posted November 14, 2012 No, they're a nice improvement over stock from what I've read. But where will you find a rear one seperately? It's the rear that needs doing anyway lolLOL true.
steve-gers Posted November 15, 2012 Posted November 15, 2012 just stick a standard rear bush in your rear mount.
ali_legend Posted November 19, 2012 Author Posted November 19, 2012 Yh that's all I need, the engine mounts look standard tbf so I just need a standard rear one plz..
ali_legend Posted November 19, 2012 Author Posted November 19, 2012 Ring Toyota you slackerHaha I'll ring them tomorrow
H_D Posted November 20, 2012 Posted November 20, 2012 (edited) Its only the rear mount which goes on the gearbox that needs to be changed,The rest are fine and sort your seatbelts out too Edited November 20, 2012 by H_D
ali_legend Posted December 12, 2012 Author Posted December 12, 2012 Bump still after a rear engine Mount!!
