bajansuperman Posted December 7, 2012 Posted December 7, 2012 anyone ever used honda pistons at 9:1 comp in a 4e and 5e. Are would i have to be the first mad man to try it jus need to know bout the wrist pin size ohh the piston r 75mm Quote
morgey Posted December 7, 2012 Posted December 7, 2012 They might be 9:1 in a honda but thats going off of all there combustion chamber designs, also the height of the piston is a main factor ie center of wrist pin to piston top will differ between manufactures. This will be what dictates the compression ratio! I supose the stroke might matter aswel as you will need clearance on the skirt of the pistons...But if they are the same then give it a go be experimental lol Quote
bajansuperman Posted December 7, 2012 Author Posted December 7, 2012 Thanks for the info i would have to get one piston to test. I know comp might be higher due to manufacture differ,but i was askin because i know hondas use vitara pistons an i know a guy that fitted vitara pistons in his 5e (covers eyes) Quote
5e colin Posted December 7, 2012 Posted December 7, 2012 wrist pin is 19 and 22mm on hondas its 18mm on e series engines Quote
bajansuperman Posted December 7, 2012 Author Posted December 7, 2012 thanks @colin.@morgey what about shaving the pistons Quote
lukEp Posted December 7, 2012 Posted December 7, 2012 You don't need to change the pistons you can increase compression by skimming the block/head. The paseo pistons are actually lower compression to the starlet ones so if you put starlet pistons in a 5e you will get higher compression. Quote
morgey Posted December 7, 2012 Posted December 7, 2012 Hes not on about raising but lowering, vitara pistons are used in honda's to run boost as a cheap alternative to forged internals. Some cars are making 450whp on them out of sohc d16's! Quote
bajansuperman Posted December 8, 2012 Author Posted December 8, 2012 (edited) @lukep its about lowering the compression and running lots of psi. @morgey yea the vitara piston seen to handle a fair amount of psi some people down here take the standard gt pistons and shave them to run more boost Edited December 8, 2012 by bajansuperman Quote
ryan lang Posted December 8, 2012 Posted December 8, 2012 can you not just use a slightly thicker HG with the fte pistons? Quote
bajansuperman Posted December 8, 2012 Author Posted December 8, 2012 well adding in things like the heat we have down here and gas quality u need more than a headgasket when running 20 plus psi but that's a good I idea to help with the built also drill the bock to fit 4agze arp bolts Quote
ryan lang Posted December 8, 2012 Posted December 8, 2012 yeah suppose so. can you not port out the combustion chamber too? Quote
bajansuperman Posted December 8, 2012 Author Posted December 8, 2012 (edited) that has to be done as vitara and Honda pistons r 75mm and up. And any porting over 75mm on e engine makes it weak Edited December 8, 2012 by bajansuperman Quote
AdamB Posted December 9, 2012 Posted December 9, 2012 Why run loads of boost? A higher compression engine gives more power, as long as it is tuned well theres no problem. If your trying to look for a safety margin you would be best going forged. Quote
lukEp Posted December 9, 2012 Posted December 9, 2012 @lukep its about lowering the compression and running lots of psi. @morgey yea the vitara piston seen to handle a fair amount of psi some people down here take the standard gt pistons and shave them to run more boostYou never mentioned running boost you were just talking about 4e and compression ratio. Quote
