dave_bristol Posted November 27, 2005 Posted November 27, 2005 hi all,im thinking that a fmic might be a good purchase soon, as i wanna get all the safety things done before upping the boost. but am unable to find a decent priced one, surely not everyone is spending 400+ for there's ? i cant seem to find one for less than this anywhere, im terrible at metal work aswell so cant buy one on ebay and make the pipes fit myself ? anyone know where i can get one cheap ?Cheers all Dave Quote
SiCaln Posted November 27, 2005 Posted November 27, 2005 Im fraid with our cars mate cheap isnt that common, i mean the Blitz one for example is £800 - best bet get onto toyotagtturbo.com check out petbeemers kit or WEPR Quote
gaz Posted November 27, 2005 Posted November 27, 2005 there are some on ebay, problem is unless your running big power the brand name wont help much, these seem good.http://cgi.ebay.co.uk/Intercooler-Starlet-...1QQcmdZViewItemhttp://cgi.ebay.com/ebaymotors/Intercooler...itemZ8013321379but im note sure how much it will cost for pipes n all.i quite like petbeemers here im thinking of getting one oneday.http://www.autofixed.co.uk/toyotastarletexhaustpage2.htm Quote
gaz Posted November 27, 2005 Posted November 27, 2005 im not aiming for high figures though only wanna do fmic and exhaust. Quote
glenn Posted November 27, 2005 Posted November 27, 2005 yes i was thinking of this aswell & seen the ones on ebay for a £100 but are they any good the top one looks good Quote
Ivan Posted November 28, 2005 Posted November 28, 2005 your options are not limited. you can go new or second hand, you can go for the cheaper brands or OEM parts off cars...generally if you just want a cheap intercooler, you go for the cheap cores that are of descent size. I would go with the ones on ebay at the top of this page. Think about it, your replacing your tiny cooler with something much bigger, regardless of its efficiency compared to other brands that size, compare the efficiency of that particular cooler to your stock one, and it will work alot better. Mind you i would look for one that has 2.5" inlets and outlets as 3" might be a bit too big.Ivan Quote
lobotomy Posted November 28, 2005 Posted November 28, 2005 Yeah Ivandr, wouldn't go for much bigger than 2.5" in/outlets. Also if they quote a pressure drop across the core, this is a good indication of the design quality of the core. The lower the, less restrictive and therefore better. Quote
gaz Posted November 28, 2005 Posted November 28, 2005 @ glenn, the £100 odd pound ones are more decent than you think mate, just because there not coated in big brand... basically just llike invandr said, its still much much better than standard for cheap money. id be stuck between choice myself. Quote
10sec_Rx7 Posted November 28, 2005 Posted November 28, 2005 Jons core is a PWR core, we use and reccomend them on everything we doDale Quote
Ivan Posted November 29, 2005 Posted November 29, 2005 PWR cores are good but quite alot of money. if you just want a front mount that will do the job but wont cost you an arm and a leg (and you wont be changing your ct9), i would go with something off ebay thats half descent, or a standard item off another car over there that is known to have a good intercooler. (for example, our ford XR6 Turbo's intercoolers are a great upgrade for our starlies, even the ends match up quite well.)Ivan Quote
10sec_Rx7 Posted November 29, 2005 Posted November 29, 2005 Considering YBY's is 175GBP it is very similer price to the dodgy ebay coolers and is a high quality cooler not a cheap cooler made in china.... Quote
Ivan Posted November 29, 2005 Posted November 29, 2005 yeah, for that price id get it... didnt realise it was pwr. Quote
glenn Posted November 29, 2005 Posted November 29, 2005 i cant get on gt turbo has any one got this lads number Quote
Robbo Posted December 4, 2005 Posted December 4, 2005 I'm getting a wepr fmic, $400-500 (which is cheap considering the exchange rate) and with pipes built for direct bolt on to the starlet Quote
glenn Posted December 5, 2005 Posted December 5, 2005 how much is that in pounds & can you keep your air con mate Quote
Robbo Posted December 11, 2005 Posted December 11, 2005 about £300 I think. Its designed to keep the air con.Autofixed also do a fmic, but that requires removal of air con I'm afraid.I wanted to keep aircon, or at least have the option, so went for WEPR. Quote
glenn Posted December 11, 2005 Posted December 11, 2005 is there any place you can look at these on line mate Quote
SiCaln Posted December 12, 2005 Posted December 12, 2005 get on ebay theres a Blitz one currently at just over 300 beans Quote
dave_bristol Posted December 13, 2005 Author Posted December 13, 2005 yeah just had a look, looks really nice but the price seems to be flying high now though DAve Quote
