starletburkie Posted January 17, 2013 Share Posted January 17, 2013 (edited) right im hopeing this is not the hg! the pipes go rock hard on boost and fills up the overflow with coolant from the rad. after a run the bottom rad pipe doesnt be as hot as the top on so maybe its the thermostat? rad cap? no mayo on oil cap etc temp stays around 85 when driving and boosting (read from the top rad pipe) any other ideas? Edited January 17, 2013 by starletburkie Quote Link to post Share on other sites
Socks Posted January 17, 2013 Share Posted January 17, 2013 That sounds like boost is pressurising the water system. Which will be head gasket failure Quote Link to post Share on other sites
starletburkie Posted January 17, 2013 Author Share Posted January 17, 2013 defo not thermostat or rad cap?? really not in the form for changing a headgasket lol Quote Link to post Share on other sites
james@cjperformance Posted January 17, 2013 Share Posted January 17, 2013 It will be th hg dude:( Quote Link to post Share on other sites
starletburkie Posted January 17, 2013 Author Share Posted January 17, 2013 only started doing this after i put in powerflex mounts and an lsd box! Quote Link to post Share on other sites
starletburkie Posted January 17, 2013 Author Share Posted January 17, 2013 anyone else any input before i buy parts? Quote Link to post Share on other sites
steve-gers Posted January 17, 2013 Share Posted January 17, 2013 Do a compression test to be 100% sure but sounds like headgasket Quote Link to post Share on other sites
micky boy Posted January 17, 2013 Share Posted January 17, 2013 Go for the cheapst first mate Buy a thremostat and new Rad cao and go from there Quote Link to post Share on other sites
starletburkie Posted January 17, 2013 Author Share Posted January 17, 2013 comp test is all good mate, engine was perfect when i took it out and now this! Quote Link to post Share on other sites
steve-gers Posted January 17, 2013 Share Posted January 17, 2013 Yeah I would do stat and cap first. I may have a cap I can send you if I can find it. Quote Link to post Share on other sites
Beastmode panda Posted January 17, 2013 Share Posted January 17, 2013 Re check the compression dude you never know!! Quote Link to post Share on other sites
starletburkie Posted January 17, 2013 Author Share Posted January 17, 2013 I've a heap of caps here and of coarse there all wrong lol must be a earlyer rad as its the type b cap (big one) in 1.3bar, ill buy a thermostat tomorro and try that Quote Link to post Share on other sites
micky boy Posted January 17, 2013 Share Posted January 17, 2013 May awell mate for the sake of £12 for a thremostat its worth a shot Quote Link to post Share on other sites
starletburkie Posted January 17, 2013 Author Share Posted January 17, 2013 fucking car really getting on my tits now lol Quote Link to post Share on other sites
akyakapotter Posted January 17, 2013 Share Posted January 17, 2013 Dose it suck the coolant back into the rad once it's cooled down ? Quote Link to post Share on other sites
starletburkie Posted January 17, 2013 Author Share Posted January 17, 2013 no it doesnt mate Quote Link to post Share on other sites
Jhandy Posted January 17, 2013 Share Posted January 17, 2013 Doing a compression test doesn't always tell you if you have head gasket failure. Do you have a head gasket tester. Try that then see what colour the fluid goes if it stays blue its fine if it goes yellow your head gasket has blownIf it stays blue. Then try a rad cap, I highly doubt it would be the thermostat because all that would do is make your car over heatWith the rad cap undo it so its at the bit where it can let the air out but the cap can't fall off, and take it up the road see if the pipes are hard or soft. If there soft then it will most likely be the rad capJake Quote Link to post Share on other sites
akyakapotter Posted January 17, 2013 Share Posted January 17, 2013 On 1/17/2013 at 10:36 PM, starletburkie said: no it doesnt mateAh that sucks mine dose this bit sucks it back into the rad once it's cooled down Quote Link to post Share on other sites
Jhandy Posted January 17, 2013 Share Posted January 17, 2013 On 1/17/2013 at 10:39 PM, akyakapotter said: Ah that sucks mine dose this bit sucks it back into the rad once it's cooled downDoes it make loads of funny noises when it does it bud. Sounds like its getting hot to me Quote Link to post Share on other sites
akyakapotter Posted January 17, 2013 Share Posted January 17, 2013 It sure dose mate then will randomly make a noise as if its letting a load of pressure out think its my rad to be honest Quote Link to post Share on other sites
starletburkie Posted January 17, 2013 Author Share Posted January 17, 2013 (edited) no hg tester, but ill try that with the cap and see Edited January 17, 2013 by starletburkie Quote Link to post Share on other sites
Johnboy GT Posted January 18, 2013 Share Posted January 18, 2013 Try removing your rrservior cap and then start your car. Leave it to run, if the water in your reservior bubbles up then you could have a cracked head or HG failure as exhaust gases are mixing with coolant.Is it using water at all?John Quote Link to post Share on other sites
Socks Posted January 18, 2013 Share Posted January 18, 2013 Coolant Smell of Fuel?? Quote Link to post Share on other sites
starletburkie Posted January 18, 2013 Author Share Posted January 18, 2013 new rad cap today and pipes not going as hard but overflow still filling up on boost! however it did suck out of the overflow when it was cold because it was half empty this morning and i left it full! still head gasket? i kinda think there is a smell of fuel but not certain, im going to do another comp test now Quote Link to post Share on other sites
Jhandy Posted January 18, 2013 Share Posted January 18, 2013 How much anti freeze is in the car. Could have a blocked radiator or something like that. Which would cause that to happen because it can't circulate. But if not. Could be head gasket Quote Link to post Share on other sites
