As above when i come to a stop. Traffic lights etc my steering wheel decides to shake it's nuts off. It isn't little vibrations it's pretty bad & is driving me mad Lol. It then stops for a few seconds then carries back on. Any help would be great it's getting really annoying :-/
Edited by Tyron Devine
Engine mounts? I'd have said wheel balancing if it was when driving
I hope it isn't :( not long since new :-/ then again so was the wheel bearing which decided to shit it's self :(
there are some silly responses to this thread, it clearly states the car isnt moving, id say rack bushes bud.
what rpm are you idling at? has it dropped and does bliping the throttle help?
Edited by har-vey
WIll be poly engine mounts that do this...
A Slight raise on your idle.... May sort it :)
I tried this yesturdsay dude still no joy. I don't mind a slight vibration but this is pretty bad.. ill post a vid up shortly it's like the steering wheel is trying to leave my car haha.
i hope it is rack bushes rather than engine mounts & the car is compleatly at a stop no movement what so ever :-)
Mine does this aswell mate drives me insane!
Have you got poly mounts? Its ever since i done my gearbox and changed to poly mounts
I actually read it as, "when I come to a stop my steering wheel shakes its nuts off"
So I presumed he was braking to come to a stop. Not really a silly response
So did I.
It'll be engine mounts does it have polys?? Can remember keirzs used to do this after he fitted the whiteline one.
It does yet Liam
Be your poly mounts... Try lowering or raising your idle to try and get away from that certain frequency where it vibrates like mad!
I Have TRD Mounts... For Exactly This Reason!
I did this already yesturday but i am going to have a good fiddle with it tomorrow, hopefully sort it out fingers crossed.
