Right..
I bought the KIm tech ECu from SD075 for a small price.
I know i didnt do much but i think its rare and i needed it in myn small collection.
Ive opend the ECU to and cant see any extra chips so maybe its only stickers they put on it in Japan?
Here are some photo's.
And here is on of a other plug and play ECU like a JAM or Blitz
Picture is from pig666eon
aztech_japan-img600x450-13646707815f3z8w
Does anyone have any idea?
All the research ive done... Suggests there needs to be another board i nthe ECU however Ive opened a HRF unit I have here for a mk1 GT and it doesnt have an extra board... I need to try it in a mk1 gt turbo to test to see if it gets rid of the limits the stock one has! :s
Thats what i was thinking.
But the last owner said it still have the fuel cut.
Now i want to try it on my own engine but i still have a stock manifold and stock cat.
Dont want to blow up my engine! :o
Edit: Last owner also said it stinks very rich on idle.
  On 4/8/2013 at 4:37 PM, glanzagee said:
Look on the underside of the board
Here you go! :)
655A17E1-B0EB-4A5E-99F0-1B68A50B6708-841
Edited by Bryan-4E-FTE
Generally the plug n play ecus do the following...
Remove Speed Limiter
Remove Fuel Cut
Raise the Rev Limiter
Tweaked Tuning
Ive never heard of an ECU doing 1 or some of them they all tend to do them all....
Socks, what is the difference between the GT P&Ps then, why is that HRF one MK1 specific ? I had no idea until ryan, whitenoize, had mentioned it.
Mk1s have slightly different wiring to the ecu
