Does anyone know if any of those type of washer jets fit on the starlet? One of the lads said try the Honda jazz ones but has anyone tried them before or can recommend any other makes?
I tried this with some Citroen ones that Clio owners use, they fitted but I was a loose fit. In the end I went back to the originals and left it at that.
I used ones from the Ford Maverick on my mX5, may not be too far off may just need one little plastic fixing removed from the washer jet underside, about £4 a side from Ford
Cheers for the info guys, will need to have a look at these jets. Hate the crappy ones on the car, look so bad and they work terribly ha I am just looking for ones on the bonnet Amjad. Don't mind trying to modify the jets to fit aswell, just if any are nearly the same size and fit then that would be good.
Looked them up, they look like they could work a treat, going to go into Ford and Mazda to see what they are like in the flesh for size wise. Mazda have the exact same ones too now.
The best one i have ever seen are the ones off a citroen c4 picasso.
But as a said, all the honda civic boys use the jazz ones so they might work ay.
  • 2 weeks later...
I've no idea mate, now my car is all MOT'd I'm going to go to ford maybe tomorrow and see what the script is with the size and stuff. Think the Honda jazz ones are around £25 these days which is a bump!
  • 3 years later...
Sorry to bring a topic back from the dead, but does anyone know of good mist jets that will fit a GT?
Was looking to order jazz jets before I came across this thread.
